[Solved] External roller shutter with remote control motor- Success works strangely
synology1 1515 4
  • #1 18437350
    synology1
    Help: 10
    Rate: 146
    Hello, maybe someone has encountered this problem or can tell me what else to check .Generally it looks like an external roller shutter operated by remote control, 2 weeks ago a strange symptom, when I want to lower the roller shutter down I press the remote control and the roller shutter flies down .When it is already down or I stop it by remote control unfortunately it does not go up anymore.Then I go to the fuse in the switchboard and pull the power for a moment, 3 seconds, the roller shutter works and I can raise it with the remote control .When I stop it again or it goes up I can't lower it, I have to pull the fuse again and after switching it on it still works once and so on and so forth if I want to control the bottom up I have to pull the power for a moment to make it work do anyone have any ideas?
  • #2 18438202
    miroslaw wielki
    Conditionally unlocked
    Help: 148
    Rate: 362
    Controller built into the engine?
  • #3 18438224
    synology1
    Help: 10
    Rate: 146
    Yes wireless control from the roller shutter only L,N,PE comes out
    Marek J.
    Help: 526
    Rate: 951
    You need to dismantle the motor, pull out the controller and check/replace the capacitors in the transformerless power supply circuit first.
  • #5 18439461
    synology1
    Help: 10
    Rate: 146
    Thank you for confirming this I feared .In that case I am waiting for better weather :)
    Roller shutter demolition
