Connection of switch and lighting in "without N" installation.
MacFis 1953 2
  • Series powering two devices from 230V mains
    #1 20359869
    MacFis
    Help: 15
    Good day
    In my flat I have an installation with light switches without a neutral wire. I currently have Zigbee modules plugged in series with LED bulbs that do not require a neutral wire to work. The switches work fine. However, I would like to replace the regular lighting with Zigbee RGBW bulbs and add Sonoffs mini in the boxes under the switches. Both units should be permanently powered. Is there any way to power the bulb and the Sonoffs in series from 230V? Unfortunately I don't have the option of replacing the installation. I was thinking of using two diodes so that each device is powered from one half of the mains:
    Both devices have inverters inside and should operate powered by half the voltage. Has anyone tried powering two devices connected in series to 230V?
    Thank you and best regards,
    Macfis
  • #2 20359904
    kindlar
    Help: 919
    Rate: 1624
    Mount the sonoff near the bulb and it will be powered all the time and from it the bulb only.
  • #3 20359914
    MacFis
    Help: 15
    Only then using the switch will I be disconnecting the power. I wanted the switch to be connected to the Sonoff input. Sonoff is only supposed to detect the state of the switch and be used for automation in HA.
