  • #1 20394625
    mavilaak
    I am trying to find out how to reset the above smart socket.
    Mine seems to have one programmed time at which the socket is switched on.
    However, when connecting it with any appropriate app, no preprogrammed time is shown.
    How to reset the device, can you help with that?
    Kind regards
    Matti Laakso
    laakso(_at_)adsl.li
  • Clarifying app, automation, and pairing checks
    #2 20395081
    Rate: 12955
    I have never heard about the socket with built-in turn off time. Is it covered in the manual?
    Which app are you using - is it a Tuya App?
    Are you 100% sure that's a programmed turn off and not a faulty device (for example, power supply fails after a random amount of time)?
    How does the socket shows up in the Tuya app?
    Have you checked the list of automations in Tuya app, maybe somehow you've added a turn off scenario?
    Have you tried to detach the socket from Tuya App and pair it again?
  • Persistent 4:30 pm switch-off after reset
    #3 20395272
    mavilaak
    Yes, I use the Tuya app and it doesn't show any kind of programmed automation for that socket. Unfortunately I haven't found a user manual for that particular device, but in the manual of LSPA6, which I assume is similar, there is no mention about a pre-programmed Switch-on time.
    The one switch-off time of exactly 4:30 pm CET remains after unplugging, unpairing and deleting of all data of the socket in the app.
    Any idea how to factory reset the Switch?
    Kind regards
    Matti Laakso
