Gosund SP111 Tasmota: Scheduling and Voltage Control Features
Mat5098 2304 1
  • Questions about Tasmota scheduling and rollback
    #1 20055395
    Mat5098
    I bought a Gosund SP111 socket, I would like to upload Tasmota to it, but I have questions about it.
    -Does this software allow you to set the socket to turn on at certain times of the day, e.g. 10:00-13:00, and between 8:00-10:00 and 13:00-18:00, when the voltage is above e.g. 250v it runs for 10 mins?
    -When it is possible to set the outlet to switch on temporarily what happens when there is no power, the time settings go off? (Apparently Tasmota works offline, without internet).
    -In case I don't like Tasmota, where can I find the software to go back to Tuya?
  • #2 20061787
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    Yes, it is possible to set a switch-on schedule.
    In a situation where there is no power the schedule will work if the time updates because the socket has no RTC.
    The only restoration option is to do a full flash dump before changing to Tasmot.
