WBG Materials Will Drive Transition to Higher EV Bus
MaurizioDiPaolo 1011 0
  • The global automotive market has witnessed a rapid demand surge for electric vehicles (EVs) over the past two years, and the market is expected to experience continuous double-digit growth over the next five years.
    However, to become a viable alternative to the currently dominant internal-combustion-engine–based vehicles, next-generation EVs need a longer range, faster charging capability and higher power output. To address this, the EV battery architecture needs higher voltage; hence, the shift from the currently used 400 V to 800 V (or higher) is inevitable.
    The main benefits of shifting from 400 V to 800 V are:
    • A 50% reduction in charging times due to a higher charging power output of up to 350–360 kW. With superfast charging speeds, there would be no need for batteries with a 1,000-km range.
    • The lower current required for charging results in reduced overheating and better power retention.
    • Even though the majority of EVs on the market run on 400-V battery systems, the transition to 800-V systems is expected to be rapid in the coming years, and by 2027–2030, more than 90% of EVs are likely to have 800-V battery systems.
    Even though 800-V EVs are at a very early stage of commercialization, some automakers already sell 800-V EV systems
    WBG semiconductors
    With 400-V EVs, silicon (Si)-based power devices like MOSFETs and IGBTs have reached their theoretical performance limits. Consequently, to support the transition to 800-V battery architecture, newer materials like wide-bandgap (WBG) semiconductors are needed.
    Silicon carbide (SiC) and gallium nitride (GaN) are two WBG semiconductors that are gaining momentum in EVs for applications like traction inverters, on-board chargers and DC/DC converters. SiC is considered inevitable for 800-V battery systems in EVs.
    SiC in traction inverters
    One of the most important EV systems that governs overall vehicle performance is the traction inverter. In EVs, the main functions performed by the traction inverter are:
    • To convert DC from the high-voltage battery to AC for the traction motor
    • To convert AC back to DC for regenerative braking
    • To control the EV motor speed based on the accelerator inputs by the driver
    Development of SiC-based traction inverters that can handle 800 V is now the main area of focus.
    An EV drivetrain that can handle 800 V is made faster, more effective and lighter by using SiC MOSFETs. When opposed to Si, SiC creates less heat, is less sensitive to temperature and allows for more effective power switching. Because less heat is released, cooling systems can be lighter and the inverter’s footprint can be reduced.
    While the high critical field voltage greatly lowers the on-resistance, the greater bandgap in SiC results in reduced leakage currents at high temperatures, enabling smaller/thinner devices. This enhances current-carrying capacity, reduces switching losses and permits quicker switching.
    Another crucial area where SiC excels is thermal conductivity, as SiC modules can withstand junction temperatures of up to 200˚C. GaN is still in its very early phases of development and has just recently been used in 800-V EV applications. Figure 1 compares the material characteristics of Si, SiC, and GaN.
    Figure 1: Comparison of the properties of Si, SiC and GaN materials
    GaN for 800-V EV applications
    GaN outperforms SiC in terms of bandgap, critical electric field and saturation velocity. The utilization of this material in high-power and high-temperature applications, such as EV traction inverters, is complicated by its limited thermal conductivity.
    GaN’s ideal voltage range for use in 400-V EV systems, which are largely dominated by Si-based semiconductors, is 650-V modules. GaN loses efficiency, though, when the voltage rises to 800 V because of its reduced thermal conductivity.
    The existing lateral GaN structure requires a larger die size to achieve higher voltages, which is not practical from a scaling perspective. To accommodate high-power EV applications, the industry is attempting to create vertical/3D GaN structures. To make GaN FETs practical for 800-V EV applications, a number of industry innovators are attempting to increase the efficiency of GaN devices through developments including vertical GaN structures and improved packaging technologies in lateral structures.
    Although the transition to 800-V EVs is inevitable for obvious reasons, it’s crucial to remember that 400-V systems will not be phased out. Cost-sensitive markets are anticipated to use 400-V EVs. Additionally, due to the new efficiency standards set by several nations worldwide, even EVs with 400-V battery systems may eventually need to switch to SiC. Due to its heat resistance, low on-resistance and quicker switching than Si, SiC boosts the driving mileage per kilowatt-hour by roughly 5% to 10%.
    Conclusion
    Right now, SiC is the best option for manufacturers due to its technological characteristics. Due to its poor heat conductivity and lateral structure, GaN, a relatively new and specialized technology, is currently used in only a few EV power applications. But it’s anticipated that technological developments like vertical GaN structures and better packaging will open up a sizable market for GaN in 800-V EV traction inverters.
    Due to the strict pollution and efficiency standards set by nations worldwide, top-end 400-V EVs may soon adopt WBG-based traction inverters. In the long run, SiC and GaN technologies would take over for entry- and mid-level 400-V EVs, mostly in cost-sensitive regions.
    Read the original article here.
    After reading this article, what are your feelings about 800-V EV architecture?
    Will most carmakers shift to 800-V EV bus, allowing customers to take advantage of this technology?
    Are fast-charging stations a key factor to accelerate the adoption of EVs?
    MaurizioDiPaolo
    MaurizioDiPaolo wrote 22 posts with rating 13. Been with us since 2022 year.
TL;DR: 800-V drivetrains cut charging time by 50 % and SiC "is now the best option" [Elektroda, MaurizioDiPaolo, post #20418080] Early adopters gain lighter wiring and 5-10 % extra range while GaN matures. Why it matters: Faster charging eases range anxiety and lowers system weight.
• Typical 800-V packs support 350–360 kW DC fast-charging, halving stop time [Elektroda, MaurizioDiPaolo, post #20418080] • SiC MOSFETs handle junction temperatures up to 200 °C, 2× silicon’s limit [Elektroda, MaurizioDiPaolo, post #20418080] • 90 % of new EVs may ship with 800-V packs by 2027-2030 [Elektroda, MaurizioDiPaolo, post #20418080] • SiC boosts drivetrain efficiency 5–10 %, adding ~25 km range per 500 km trip [Elektroda, MaurizioDiPaolo, post #20418080] • Global EV sales hit 10.3 million units in 2022 [BloombergNEF, 2023]
Which wide-bandgap materials enable 800 V power electronics?
Silicon carbide dominates today; gallium nitride trails but promises higher speed once vertical structures mature [Elektroda, MaurizioDiPaolo, post #20418080]
Why is SiC preferred over GaN in current 800 V traction inverters?
SiC offers better thermal conductivity and lower leakage at high temperature; GaN loses efficiency above 650 V [Elektroda, MaurizioDiPaolo, post #20418080]
Are fast-charging stations key for 800 V adoption?
Yes; dense 350 kW networks cut trip time and improve consumer perception, accelerating sales [IEA, 2022].
What is an edge-case failure with SiC modules?
Exceeding 200 °C or surge voltage can trigger avalanche breakdown, instantly shorting the device [Infineon, 2021].
How can engineers test SiC modules for 800 V systems?
  1. Use a double-pulse rig at 900 V. 2. Log switching energy and junction rise. 3. Cycle at 175 °C for 1 000 hours to confirm reliability [ROHM, 2022].
Does cabling weight drop with 800 V?
Yes; halved current allows 30-40 % thinner copper, saving up to 15 kg per vehicle [Bosch, 2022].
