GNSS (GPS) module for ESP32 module to provide the most accurate coordinates possible
CC_PL 822 2
  • Request for accurate GNSS module with Galileo support
    #1 20445895
    CC_PL
    Rate: 57
    I am looking for a GNSS module under the ESP32 board (exactly ESP32-D0WD , revision three).
    I am keen on:
    - as accurate positioning as possible (and therefore support for Galileo satellites) and if possible input to an external antenna.
    - easy integration with the ESP32-D0WD-R3 module
    - libraries in C or C++ or MicroPython, possibly Rust.
    - good documentation and in English or Polish, not e.g. in Chinese.
    What can you recommend? I am not sticking to the ESP32 chip, if there is a much better GNSS/GPS chip for Raspberry or Arduino, I would be happy to hear your suggestions.
    Thanks for your help!
    CC
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    Choose something from the Quectel range
    E.g. model LR-80R or L76-LB Processor any environment.
  • #3 20469952
    CC_PL
    Rate: 57
    Thank you, but I'm over the selection and purchase. Although I may take an interest in the Quectel in the future, on another project.
