Connecting the Smart Tuya Wi-Fi switch to the power supply for desk top control
bonss 1692 7
  • Clarifying whether Tuya switch can control a power supply
    #1 20530735
    bonss
    I would like to connect a smart Tuya WI-FI switch under a power supply to install such a switch in a desk top. Obviously, no lighting will be physically connected to it, it will only be used for WI-FI control.
    Can this be done?
    Connecting the Smart Tuya Wi-Fi switch to the power supply for desk top control [/url] Connecting the Smart Tuya Wi-Fi switch to the power supply for desk top control Connecting the Smart Tuya Wi-Fi switch to the power supply for desk top control
  • #2 20530739
    freebsd
    Help: 766
    Rate: 2033
    Do you want to control the power supply with such a switch?
  • #3 20530740
    sosarek
    Help: 9320
    Rate: 15532
    Under which power supply?
    Since nothing will be connected to it, how will it control anything?
    Z
    Pka, Poznań, 60-850
  • Clarifying that the Tuya switch only needs power for automation
    #4 20530747
    bonss
    I may have written imprecisely.
    At the moment in some rooms I have such a switch connected to the main lighting, plus two connectors in the switch are unconnected. Using the smart life app, I have programmed them so that, for example, in the bedroom, one button turns off the lighting throughout the house.
    I thought it would be nice to have such a switch in the desk to control the lighting. Nothing will be physically connected to it, everything will be controlled by automation in smart life.
    When connecting the power supply I am concerned with providing it with the necessary voltage for the smart function. I do not want to control the power supply :D .
  • Connect L and N without a lamp load
    #6 20530936
    freebsd
    Help: 766
    Rate: 2033
    bonss wrote:
    By connecting the power supply I mean to provide it with the necessary voltage for the smart function.
    That is, you have L and N (phase and neutral wire) available at the switch connection point. This simplifies things, you don't need to use any additional load in the form of a lamp or power supply.
    Connect L and N to the switch, don't connect the lamp - program and control :-) This is the connection as on the left of the picture from your first post" with neutral".
    Maybe it would be easier to use a "Tuya remote control"? I have these battery-powered quadruple and triple in a housing resembling wall switches, but I also have one in a small housing the size of a gate remote.
  • #7 20531026
    bonss
    Thanks that's exactly what I meant :-)
    I have a few switches left, hence the idea.
  • #8 20531093
    freebsd
    Help: 766
    Rate: 2033
    Add Amazon Alexa to the mix - you won't have to 'search' for the switch. Especially useful for turning off lights :-) .
The discussion revolves around connecting a smart Tuya Wi-Fi switch to a power supply for desktop control without any physical load, such as lighting. The user seeks to utilize the switch for automation via the Smart Life app, allowing control of lighting throughout the house. Responses clarify that the switch can be connected directly to the live (L) and neutral (N) wires, enabling its smart functions without needing a connected load. Suggestions include using a Tuya remote control for added convenience and integrating Amazon Alexa for voice control.
