OpenBeken - increase ping watchdog interval (decrease frequency)
bairan24 2052 4
  • #1 20537199
    bairan24
    Level 4  
    tell me, is it possible to increase the time between ping watchdog requests? my router is blocking a device that pings a lot every second
    PingInterval command added for ping watchdog
    #2 20537336
    Rate: 12914
    Hello, the following option has been added recently, but indeed docs weren't build after that.
    The command is PingInterval [TimeSeconds]. Please check if it's working for you.
    Keep in mind that setting PingInterval to value larger the one you use in script to trigger event won't work well, it will trigger event every time.
    addChangeHandler noPingTime > 600 reboot
    Please see here:
    You can scroll down to ping watchdog sample.
  • #3 20537399
    bairan24
    Level 4  
    thank you, the team is accepted, the interval has increased. the interval made sure that 2 pings had time to pass before the script time I will test
  • #4 20538790
    Rate: 12914
    Hello, how's the test going? Is ping interval configuration working?
  • #5 20542292
    bairan24
    Level 4  
    so far everything is successful, the interval has increased, it has been working stably for 3 days
