OpenBeken MQTT: Status changes despite adjustment of mqtt_broadcastInterval to 90 seconds
rogerrabbit19501 2550 2
Treść została przetłumaczona german » english Zobacz oryginalną wersję tematu
  • mqtt_broadcastInterval ignored for status updates
    #1 20810514
    rogerrabbit19501
    I have a problem with OpenBeken and mqtt. I want the status changes to be sent only every 90 seconds. Therefore I have adjusted the parameter mqtt_broadcastInterval 90. Nevertheless, every status change is sent. Below is an excerpt from the log:
    Info:MQTT:MQTT client in mqtt_incoming_publish_cb topic plug/washing/1/get
    Info:MQTT:MQTT client in mqtt_incoming_publish_cb topic plug/washing/current/get
    Info:MQTT:MQTT client in mqtt_incoming_publish_cb topic plug/washing/energycounter/get
    Info:MQTT:MQTT client in mqtt_incoming_publish_cb topic plug/washing/energycounter_last_hour/get
    Info:MQTT:MQTT client in mqtt_incoming_publish_cb topic plug/washing/energycounter_yesterday/get
    Info:MQTT:MQTT client in mqtt_incoming_publish_cb topic plug/washing/energycounter_today/get
    Info:MQTT:MQTT client in mqtt_incoming_publish_cb topic plug/washing/energycounter_clear_date/get
    Info:MQTT:Publishing val 234.0 to plug/washing/voltage/get retain=0
    Info:MQTT:MQTT client in mqtt_incoming_publish_cb topic plug/washing/voltage/get
    Info:MQTT:Publishing val 1.00 to plug/washing/power/get retain=0
    Info:MQTT:MQTT client in mqtt_incoming_publish_cb topic plug/washing/power/get
    Info:MQTT:Publishing val 0.00 to plug/washing/power/get retain=0
    Info:MQTT:Publishing val 234.6 to plug/washing/voltage/get retain=0
    Info:MQTT:Publishing val 0.007 to plug/washing/current/get retain=0
    Info:MQTT:Publishing val 236.0 to plug/washing/voltage/get retain=0
    Info:MQTT:Publishing val 235.4 to plug/washing/voltage/get retain=0
    Info:MQTT:Publishing val 0.003 to plug/washing/current/get retain=0
    What am I doing wrong?
    Does anyone else have this problem?
    OpenBeken version 1.17.303
    LG
    Roger
  • #2 20810796
    Rate: 12914
    I think the frequency of sending voltage information changes is determined by another command, VCPPublishIntervals :
    Table with VCPPrecision, VCPPublishIntervals, and VCPPublishThreshold commands and their descriptions.
    See more at:
  • #3 21246334
    hansreutinger
    Thank you very much.
