OpenBeken - How to turn off relay after 1-2 seconds; autoexec.bat script example/change handler
kinziulisKinziulisLT 1713 3
  • #1 20559874
    ElektrodaBot
    How to make it so that after switching on the status relay, it would be 2 seconds, and then turn off?
    Auto-off relay script using addChangeHandler and addRepeatingEvent
    #2 20560056
    Rate: 12881
    @kinziulisKinziulisLT that bot has the knowledge of ChatGPT, so it's up to 2021. OpenBeken did not exist at that time.
    And to answer your question:
    // This will automatically turn off relay after about 2 seconds
    // NOTE: addRepeatingEvent [RepeatTime] [RepeatCount]
    addChangeHandler Channel0 != 0 addRepeatingEvent 2 1 setChannel 0 0
    Assuming that your relay is on channel 0, and setting channel 0 to 1 enables relay, then this code will turn off relay always 2 seconds after turning it on.
    Let me know if you need anything more. The following script will always make relay go off after 2 seconds.
    If you want to do something else, for example invoke it from MQTT, then you can do:
    alias My_Relay_Cycle backlog setChannel 0 1;  addRepeatingEvent 2 1 setChannel 0 0
    and then you can use command My_Relay_Cycle, for example from MQTT cmnd topic.
    Then that command will set channel 0 to 1 (relay on), wait 2 seconds, and set channel 0 to off.
  • #3 20560105
    create autoexe.bat
    addChangeHandler Channel1 != 0 addRepeatingEvent 1 1 setChannel 1 0
    addChangeHandler Channel2 != 0 addRepeatingEvent 1 1 setChannel 2 0
    addChangeHandler Channel3 != 0 addRepeatingEvent 1 1 setChannel 3 0
    addChangeHandler Channel4 != 0 addRepeatingEvent 1 1 setChannel 4 0
  • #4 21710914
    Rate: 12881
    I have unlocked your topic per request. How may I help you futher?
