Peugeot 206 (2004) 1.9 Diesel Wiring Diagram for Lucas ECU & Siemens B3 BSM
faqndin 885 0
  • Need wiring diagram for burned ECU-to-BSI harness
    #1 20636688
    faqndin
    Hello, could you please help me with the Peugeot 206 1.9 diesel diagram, 2004 model? This model has the Lucas ECU, and the BSM is Siemens B3. My problem is that the cables burned and I couldn't find any diagram that is consistent with what that branch is healthy. Thank you very much. I need to be able to replace the cables and ensure that they go to their correct location. The branch is the one that goes from ECU to BSI, with sensors, etc. VIN number is 8AD2AWJYU4G021247 MOTOR DW8B.
