Split one GDN and 3.3v/5v pin into six for sensor connection
Michal8883 675 3
  • #1 20678458
    Michal8883
    Rate: 11
    How can I make one GDN pin and a 3.3v or 5v pin into several pins, e.g. 6 each, to connect several sensors?
  • #2 20678498
    austriackimalarz
    Help: 83
    Rate: 266
    Aaa, because there are no commas here! After a long while I realised that there are 3 pins total here. Also...
    Depends what the sensors are. It would be best to use a separate circuit with multiple outputs, and digitally communicate it over this one pin.
  • #3 20678530
    Michal8883
    Rate: 11
    And what is such an arrangement called for pin splitting?
  • #4 20813324
    rolnik666
    Probably a multiplexer - if we are talking about inputs/outputs for communication.
