[Solved] Simplifying ESP8266 Code to Display Only Temperature from DS18B20 Sensor
slowik359 894 4
  • ESP8266 code still includes Blynk and relay logic
    #1 20724796
    slowik359
    Level 4  
    Code: C / C++
    Sample ESP8266 code for DS18B20 temperature display
    #2 20724806
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    slowik359 wrote:
    Blynk.virtualWrite(VPIN_coolerbtn, coolerState);
    if (modeState == 0)
    display.setTextSize(1); // Draw 2X-scale text
    display.setTextColor(SSD1306_WHITE);
    display.setCursor(32, 45);
    display.print("Manual Mode");
    display.display();
    delay(3000);
    It looks like the code you provided is incomplete. However, I can give you a basic concept of how the code can be updated to display the temperature measurement from the DS18B20 sensor on the OLED display and send the data to the Blynk application.
    I assume you are using libraries that support the ESP8266 module, DS18B20 sensor, OLED display and Blynk.
    Below is sample code that shows how to do what you are describing:
    Code: text
    Assuming the DS18B20 sensor is connected to pin D2 on the ESP8266 board, this code will read the temperature from the DS18B20 sensor, display it on the OLED display, and then send it to the Blynk application.
    Substitute "YourAuthToken", "YourNetworkName" and "YourPassword" with your Blynk token, Wi-Fi network name and password.
    This code is fairly simple and does not include error handling, so you will probably want to extend it to better suit your needs.
    Please note that you will need to install the required libraries in the Arduino IDE environment. These libraries are: Adafruit_GFX, Adafruit_SSD1306, OneWire, DallasTemperature, ESP8266WiFi, BlynkSimpleEsp8266.
    Hope this helps! If you have any questions, feel free to ask.
    #3 20724883
    slowik359
    Level 4  
    Code: C / C++
    The whole code. I will check tomorrow
  • #4 20725767
    slowik359
    Level 4  
    I have uploaded what they specified
  • #5 20729002
    slowik359
    Level 4  
    as they wrote
