HP Elite 8300 SFF - 5.25 and 3.5 bay bezel
VIGOR_PICTURES 2445 2
  • A custom 3D-printed bezel restores the front of an HP Elite 8300 SFF after removing the 5.25-inch and 3.5-inch drive bay caps for extra storage.
  • The bezel was modeled in Blender from scanned cardboard templates, using caliper measurements, bridge tools, and a boolean cut to match the case's rounded front and ventilation slots.
  • The print took 10 hours on an Ender 3 Pro with a 0.3 nozzle, using white PLA that cost about 4.5 PLN.
  • The finished part was sanded, painted matte black, and clear-coated, then attached with hot glue and good intentions.
  • One flaw remains: the bezel's slots do not line up with the case slots, and a harder sanding pass could hide the visible steps.
  • Front view of an HP Elite 8300 SFF office computer.
    As we know, people are divided into two types. Those who will do backups and those who already do. I belong to the latter group.
    For this purpose, I found a use for an HP Elite 8300 SFF office computer.
    The whole thing works with urBackup as software. In order to fit up to three 3.5 inch drives and one 2.5 inch Sata SSD, I had to get rid of the drive rack in the 5.25 and 3.5 bays.
    For the platter drives I made a cage out of a plastic ventilation duct, routed power from the motherboard for a small 70mm fan and modified the power cable for the drives.
    On the visual side, the change was simple. I got rid of the 5.25 and 3.5 caps.
    The hardware side is boring. Possibly a quick photo from the top:
    Interior of an HP Elite 8300 SFF computer showing the motherboard, power supply, and hard drives.
    I didn't bother with the lack of dentition as long as the server was behind the couch. Recently, the server took up space under the desk and that meant it was visible (no plugs and just a rectangular indentation in the front of the case). To make matters worse, it was within easy reach of the hands of two future electrode regulars :D .
    I had originally planned to design and print the whole front of the case, but laziness got the better of me and it fell to the grille.
    HP Elite 8300 SFF office computer with visible front panel.
    (Above is a picture of a typical HP Elite 8300)
    However, there was a problem - the front is rounded.
    Usually, all we had to do was gather the dimensions with a caliper and the subject was settled. In the end, I used calipers (overall dimensions of the indentation in the front of the case, width of the ventilation slots) and ordinary pieces of paper to design the fitted bezel, of course.
    I'm already explaining. I saw that the height of the opening was 82.5mm, so I cut a piece of card to this length, applied it to the opening and drew the shape on one side and the other with a pen. The cards were then scanned, straightened and colour processed in Photoshop and then thrown into Blender to model the grille.
    By trial and error, I found a scale factor where a scanned square of 10mm would correspond to a virtual square of 10mm. For a full scan taken by a Canon MP550, the image needs to be scaled up to a value of 59.282. The image below shows what this is all about:
    Screenshot of Blender software showing a model of a scanned paper note with marked scale.
    The scanned card had exactly the same width in Blender as measured with the caliper.
    Since I already had the curves (two different ones - the case is more convex in the middle than on the side) of the case transferred to Blender to the first step was to merge the pieces. To the rescue here comes the bridge option available in vertex edit mode under W->Loop Tools.
    Modeling a computer case front cover in Blender.
    I then modelled another object, which was the exact inverse of the ventilation slots. Next, it was a formality to use the boolean (difference) operator on the modelled front piece.
    A very helpful tool is a free plugin that checks the model for 3D printing.
    The process of designing a cover in Blender.
    (Modelled full bezel, extrusion and use of boolean modifier)
    In a nutshell, designing any part in Blender for 3d printing looks like this:
    1. Model the object using any technique (in my case, modelling from a scan and using a second model as a "extrusion"
    2. In vertex editing mode we use the 3D Print extension we check if our model is correct (by clicking the "Solid" button) and very often for simpler errors "Make Manifold".
    3. Once in object manipulation mode, we use the shortcut Ctrl + A and select 'Rotation and Scale'. This is necessary because sometimes Blender uses a different scale than the print program.
    4. We export our model to a *.STL file with "Selection Only" selected and leaving the Scale at the default value (1.00)
    Screenshot from Blender showing the STL file export window.
    Then just have the 3D printer print.
    3D-printed ventilation cover held in a hand. 3D-printed grille held in a hand. Person holding the front panel of an HP Elite 8300 computer case with visible ventilation slits. Close-up of the front panel of an HP Elite 8300 SFF computer case, with a hand holding the computer, showing ventilation holes. Person holding a computer bezel in front of a monitor screen. Close-up of the front panel of an HP Elite 8300 SFF computer held in hand. Close-up of the front panel of an HP Elite 8300 SFF computer held in hand.
    The Ender 3 pro took 10 hours to print (nozzle 0.3). Of the additional options, only "Ironing" (smoothing the top flat layers). The print is Plast-Spaw white PLA. The cost of the filament is about 4.5 PLN. I lightly sanded the bezel with 120 paper on a "washing up sponge" and dusted it off. Then a matte black acrylic varnish went on it and after a few minutes a clear coat.
    What would I change? In the future, I would definitely project the piece during the day (in the sense of not being tired). The slots in the bezel do not match the slots in the front. This is a typical design error ("What was I thinking?!"), but it doesn't bother me too much because the computer is sitting under my desk. It is possible that I would have mounted the front differently to the case (press-fit). The last thing could be to grind the bezel harder, so that the "steps" are not visible.
    I have attached my bezel to the topic as an STL file. If anyone finds it useful - great. If someone needs it they can "home-model" their own connection system to the front of the case (in my case it's hot glue and good intentions).
    Stay tuned.
    Aha, the password is the name of our portal ;)
    • hp_front_mesh.zip (34.99 KB) You must be logged in to download this attachment.
    VIGOR_PICTURES
    VIGOR_PICTURES wrote 871 posts with rating 148, helped 20 times. Live in city Warszawa. Been with us since 2006 year.
  • Syncthing with versioning as live backup solution
    #2 20736055
    gulson
    System Administrator
    Help: 150
    Rate: 6130
    Interesting idea, especially as our backup server is in plain sight.
    I haven't heard anything about urBackup - interesting open source solution.
    The only thing that worries me is the energy costs. Hence I opted for a Raspberry Pi and such a terminal for a few hundred zloty.
    I put syncthing on it to synchronise files between devices.
    You can think of it as a live backup and at the same time all the devices have the same files.
    I also added versioning, should one device suddenly decide to dump files ;)
    As they say, people are divided into those who do backups and those who are about to do them ;)
    Text me a packet and I'll send a small gift.
  • Measured HP Elite 8300 SFF power draw under backup load
    #3 20737751
    VIGOR_PICTURES
    Help: 20
    Rate: 148
    Hi.
    The server is not running all the time, hence I am not heavily worried about the strain on the household budget. It is usually running in the evening when I am doing a course in game development. All in all, you have inspired me to get comfortable with measurements. I will stipulate that the results may be inaccurate as this is a measurement using a "Smart socket".
    Anyway:
    The server (i3-2120, 1x2.5 SSD 2x3.5 inch HDD, 8GB there DDR3) in idle mode draws about 25-30W. During backup, typical power consumption is around 45W (with occasional peaks around 50W). Maximum power consumption from the socket (Cinebench r23) is 61W.
    App screen displaying electricity usage in kWh for the current day, along with data on current, power, and voltage. App screen showing electricity consumption.
    UrBackup is a very pleasant piece of software that does have a spartan user interface, but as far as I'm concerned that's an advantage. It allows you to make copies of entire drives as well as folders/files. Additional features include email alerts if something is wrong. I won't write more, as I myself use only the simplest functionality (backup of the system disk and a few folders from RAID0)
    For the time being, it only works on my computer as a backup, but I plan to connect my wife's computer.
TL;DR: DIY a curved 5.25/3.5" bay grille for an HP Elite 8300 SFF; one Ender 3 Pro print took 10 hours. “People are divided into those who do backups and those who are about to do them.” [Elektroda, gulson, post #20736055]
Why it matters: This helps home users and tinkerers hide open bays, add drives, and keep backups tidy.
What is this HP Elite 8300 SFF bezel mod?
It replaces the missing 5.25/3.5" bay covers with a custom 3D-printed grille. The mod also frees space for additional drives and improves appearance for visible setups. It targets backup servers built from office desktops. [Elektroda, VIGOR_PICTURES, post #20735707]
How do I capture the Elite 8300’s curved front profile without CAD tools?
Cut card to the opening height (82.5 mm), trace both sides against the case, scan, then clean in Photoshop. Import the cleaned outlines into Blender for modeling. This preserves the center and side curvature differences. [Elektroda, VIGOR_PICTURES, post #20735707]
What scan-to-Blender scale factor worked for a Canon MP550?
A full-bed scan required scaling to 59.282 so a 10 mm scanned square matched 10 mm in Blender. This ensured accurate dimensions before modeling. [Elektroda, VIGOR_PICTURES, post #20735707]
How do I model and prep the grille in Blender for 3D printing?
  1. Model the front piece from the scanned curves and bridge profiles.
  2. Create a second object for slot geometry and apply a boolean difference.
  3. Run 3D Print checks, then Ctrl+A → Rotation & Scale, export STL at scale 1.00. [Elektroda, VIGOR_PICTURES, post #20735707]
What printer, filament, and settings were used?
An Ender 3 Pro printed the grille in about 10 hours with a 0.3 mm nozzle. PLA filament was used, followed by light sanding, matte black acrylic, then clear coat. Filament cost was ~4.5 PLN. [Elektroda, VIGOR_PICTURES, post #20735707]
How is the bezel mounted to the case?
The shared STL supports several approaches. One build used hot glue for a simple, secure press-like fit. You can redesign the attachment in CAD if needed. [Elektroda, VIGOR_PICTURES, post #20735707]
Do the grille slots align with the factory front vents?
Not perfectly in the documented print. The author notes a design oversight and visible layer steps when viewed up close. It still looks tidy under a desk. [Elektroda, VIGOR_PICTURES, post #20735707]
How many drives can this SFF build carry after the mod?
The example fits up to three 3.5" HDDs plus one 2.5" SATA SSD. A plastic ventilation-duct cage holds the drives securely. [Elektroda, VIGOR_PICTURES, post #20735707]
How is cooling handled with the added drives?
Power for a small 70 mm fan is taken from the motherboard. The fan helps move air across the drive cage built from a ventilation duct. [Elektroda, VIGOR_PICTURES, post #20735707]
What is the real-world power usage of this backup server?
With an i3-2120 and mixed drives, idle draw is 25–30 W. During backups it averages ~45 W, peaking near 50 W. Cinebench R23 puts it near 61 W. [Elektroda, VIGOR_PICTURES, post #20737751]
Is urBackup suitable here, and what can it do?
Yes. urBackup handles whole-disk and folder backups, with email alerts. The interface is spartan yet effective. “A very pleasant piece of software.” [Elektroda, VIGOR_PICTURES, post #20737751]
What is Syncthing, and why consider it?
Syncthing synchronizes files across devices for a live backup feel. One builder paired it with a low-cost terminal or Raspberry Pi to reduce energy use. [Elektroda, gulson, post #20736055]
Does the server run 24/7, or only during backups?
In the shared setup, it runs mainly in the evenings during coursework and backups. That limits energy costs while meeting needs. [Elektroda, VIGOR_PICTURES, post #20737751]
Any measurement or accuracy caveats to note?
Power readings came from a smart socket, so results may be approximate. Also, design when tired led to slot misalignment. Measure carefully. [Elektroda, VIGOR_PICTURES, post #20737751]
What finishing steps improve the printed bezel’s look?
Lightly sand with 120-grit on a sponge, dust off, spray matte black acrylic, then add a clear coat. This hides layer lines. [Elektroda, VIGOR_PICTURES, post #20735707]
