[BK7231N - CB3S] Generic Tuya Wall Switch Touch Type 1-3 Gang with Neutral and also a Dimmer
theslydog 1026 0
  • CB3S pinout and OpenBeken dimmer setup
    #1 20758883
    theslydog
    Level 4  
    This is a short teardown of US type Generic Tuya Touch Wall Switch (With Neutral) with CB3S module.
    Basic information:
    Brand: Shawader (Tuya based)
    Model: WiFi Touch Switch & Dimmer WiFi Touch Switch
    Chip: BK7231N [CB3S]
    Local Vendor:To view the material on this forum you must be logged in.
    These switches look a lot like Makegood switches.
    To view the material on this forum you must be logged in. To view the material on this forum you must be logged in. To view the material on this forum you must be logged in.
    Main Module version in the Tuya app was V1.1.0 on the switch and V2.1.6 on the Dimmer.
    These can be flashed with Tuya-Cloudcutter.
    I used the option 2 > By firmware version and name.
    There is a V1.1.0 'dctrl switch' and V2.1.6 'common user config ty' file that both flashed fine.
    I think from memory they both flashed OpenBeken-v1.17.130_bk7231n.ug.bin
    This is only the one gang version but I would assume the 2,3,4 would be similar.
    This is what worked for me, I found with the switch that if I used WIFILED_n then the off blue was too dark so used LED_n instead the wifi led is under the cover anyway so you cant see it.
    Pinout:
    1 Gang
    P10 Btn
    P11 LED_n
    P26 Rel
    The Dimmer autoexec.bat
    startDriver TuyaMCU
    setChannelType 1 toggle
    setChannelType 2 dimmer
    tuyaMcu_setDimmerRange 2 1000
    linkTuyaMCUOutputToChannel 1 1 1
    linkTuyaMCUOutputToChannel 2 2 2
    Hopefully this is useful to some.
