Two Amazon Echo speakers, Alexa - play different music simultaneously
DakotaPL 3279 9
Can two Amazon Echo speakers in different rooms play different music at the same time?
Yes, but not when both devices are effectively tied to the same music playback session; in this thread it only worked after resetting the speakers and using different playback sources, with one Echo playing RMF FM radio and the other playing Spotify from the phone [#21107340] [#21107411] Changing the wake word alone (Alexa/Echo) did not fix it, and the final conclusion was that Spotify was the source of the problem [#21107259] [#21107411]
  • Alexa Echo speakers cannot play different music simultaneously
    #1 20829680
    DakotaPL
    Hi
    I have a question about Echo speakers and the Alexa system
    When I have two such speakers in different rooms and added to one Alexa application, can I listen to music at the same time a different one on each speaker?
    I mean, two people in different rooms would like to listen to each other's music.
    I have seen many descriptions of how to make a multi-room and play the same thing on all of them, but this just does not interest me.
    I added each speaker to a different room. When I tell Alexa to play music in, for example, the living room, it immediately turns off the one that is in the other room.
    I don't even want voice control, but so that I can play my music when I'm actually working and my wife at the same time listening to something else in the other room
    Is this possible?
    Greetings
    My wife.
  • Different accounts may be required for simultaneous playback
    #2 20829863
    gulson
    System Administrator
    Help: 150
    Rate: 6128
    Unfortunately it seems to me that you would have to connect the speakers to different profiles - accounts.
    Maybe a separation in the settings into different rooms would suffice, in the sense of selecting in the settings that the speakers are separated by different rooms.
    And why I am writing about different accounts, it is possible that there could be, for example, licensing involved, that can use one account and one music playback session at the same time. This is, for example, the case on Spotify without a family account.
  • #3 20830712
    DakotaPL
    Thanks for the reply
    I will be testing at the weekend. For now, I have split the speakers into two rooms. They play together or separately, but together it's exactly the same.
    I'll also try with a two-account setup, maybe that will be the solution
    I'll definitely let you know what I got out of it.
  • #4 21067744
    osuchdominik
    And what came out? I am also interested in listening to different music in two different rooms at the same time and can't find the info
  • #5 21071790
    DakotaPL
    Sorry for the delay in replying, but I had some time off.
    Unfortunately I was not able to make the speakers play different music at the same time. I tried various options but finally gave up. Of course I'm not saying it's not possible, but I at least haven't found a way. Either one plays or the other.
  • #6 21106166
    DarekQ8
    >>21071790 >>21071790 an easy way is to change the wake word of the device, e.g. instead of alexa use e.g. ECHO this possibility is in the device settings under the name "wake word" you can choose from: alexa, amazon, computer, echo or ziggy.
  • #7 21107259
    DakotaPL
    Thank you for the hint. After the change unfortunately it doesn't work, I mean it works one on Alexa, the other on Echo, but when I turn on one speaker the other one stops playing. Maybe something else needs to be changed?
  • #8 21107340
    DarekQ8
    And what are you playing music from? Maybe you have some kind of playback device paired to both speakers. My suggestion is to go for broke and reset both speakers. I have just tested at my place and unfortunately it works for me. Echo plays RMF FM radio and Alexa on the phone plays music from Spotify.
  • #9 21107411
    DakotaPL
    I did as you wrote and it works on both meaning it was a Spotify issue, thanks for your help
  • #10 21107426
    DarekQ8
    >>21107411 Any Time.
The discussion revolves around the challenge of playing different music simultaneously on two Amazon Echo speakers using the Alexa system. The user inquires if it's possible to have each speaker play distinct music in separate rooms without one stopping the other. Initial suggestions include setting up different user accounts or profiles for each speaker to avoid licensing issues, as seen with services like Spotify. The user tests various configurations, including changing the wake word and resetting the devices, but initially fails to achieve the desired outcome. Ultimately, the user discovers that the issue was related to Spotify, and after adjustments, both speakers can play different music simultaneously.
