Firmware update for the IH-K009 sensor - Tuya Smart Compatibility
PSlowik 2304 6
  • #1 20867349
    PSlowik
    Hello, I have a question if it is possible to upload any other firmware to the IH-K009 there is exactly this:
    https://solution.tuya.com/hardware/detail/61005
    I am asking because I have a couple of pieces of this and it was working and then suddenly stopped :/
    the worst thing is that using a new piece does not bring anything also does not work :/
    thank you for the info
  • #2 20868218
    Rate: 12954
    After all, it's a sensor on Zigbee, right? What do you want to flash there
    Is it unresponsive to reset?
  • #3 20871821
    PSlowik
    yes zigbee.
    unfortunately, I don't know why, but it stopped working, i.e. it works but strangely reports temp as it pleases :/ sometimes 2 min sometimes 2h other time 8h :/
  • #4 20871828
    Rate: 12954
    Batteries new?
  • #5 20871845
    PSlowik
    new and 100% shows
  • #6 20871851
    Rate: 12954
    I don't really know what could have gone wrong there. Maybe unplug these devices and pair again
    Some Zigbee devices had the ability to trigger a previous measurement by pressing a button. Users sometimes modified Aqara devices to permanently short out the button and get more frequent measurements. Perhaps this would help in your case?
  • #7 20871955
    PSlowik
    this one doesn't have any button :(
    I removed and reconnected from 50x unfortunately 0 effect :/ I got frustrated and threw it away and made for esp sensor. :( no idea and most interestingly another 2 pcs are still working and reporting BDB
The discussion revolves around issues with the IH-K009 Zigbee sensor, which has stopped functioning correctly, reporting inconsistent temperature readings. The user inquires about the possibility of uploading alternative firmware to the device, as they have multiple units, some of which are still operational. Responses suggest checking the device's reset functionality, ensuring new batteries are used, and attempting to re-pair the devices. However, the user notes that the IH-K009 lacks a button for manual resets and has already tried reconnecting multiple times without success, leading to frustration and a switch to an ESP sensor for their needs.
