CB3S / BK7231N: Generic Tuya wireless temperature/humidity sensor with LED
lukedashjr 4485 12
How can I stop OpenBK7231N from crashing or being powered off after about 30 seconds on a CB3S/BK7231N Tuya temperature/humidity sensor?
Your CB3S is probably being power-cycled by the TuyaMCU after about 25–30 seconds because it expects the Wi‑Fi module to send UART data first, so this is likely a TuyaMCU integration issue rather than just a bad flash size [#20195500][#20195154] A reported workaround for the BK7231N platform was flashing a full 2 MB image so the config/other partitions are overwritten, then changing the MAC afterward [#20185926] The suggested software path is to start both the `tuyaMCU` and `tmSensor` drivers, ideally from `autoexec`, and have the Wi‑Fi module send the expected packets/heartbeat/product info soon after boot [#20196499][#20195500] If it keeps tripping safe mode, lower the boot-failure threshold in settings [#20195500] For debugging, power the Wi‑Fi module permanently from 3.3 V and observe the UART traffic against the original firmware so you can see what the MCU expects [#20200359][#20205435]
  • OpenBK7231N firmware crashes and may be too large
    #1 20185849
    lukedashjr
    CB3S / BK7231N: Generic Tuya wireless temperature/humidity sensor with LED CB3S / BK7231N: Generic Tuya wireless temperature/humidity sensor with LED
    Was able to flash OpenBK7231N_QIO_1.12.54.bin, but it crashes within a minute of booting (whether wifi is configured or not).
    I can only read the first 1150976 bytes, and observe the OpenBK images are 1220464 bytes - so maybe they're too big? idk
    Had to boot up a Windows system to use encrypt.exe to decrypt the factory firmware backup and get it back to stock...
    Added after 10 [minutes]:
    P.S. If someone wants me to try anything, the clock is ticking: I got this specifically because it said it supported below freezing, but it doesn't (the LED display went nuts). So regardless of firmware hacking stuff, I'm returning it.
    P.P.S. Any suggestions for a non-cloud-able (preferably open source firmware) temperature/humidity sensor that runs on batteries and I can stick in freezers?
  • Full 2 MB flash as temporary BK7231N fix
    #2 20185926
    Rate: 12973
    Is this a TuyaMCU device? It certainly looks like it.
    Have you tried older OBK version?
    The N platform problem was already reported and a temporary solution that we came up with was to flash full 2MB and thus override all config etc partitions. See attachment. Try flashing it.
    Remember to change your MAC in settings afterwards
    The issue is problematic to debug, because for me, on my few N devices, everything seems to work.
    it's almost like only the new batches from factory are affected
    • FullFW.bin (2 MB) You must be logged in to download this attachment.
  • Need full 2 MB flash backup before trying override
    #3 20187254
    lukedashjr
    I don't know how to tell, but other threads here suggested UART flashing would fail with TuyaMCU, and it didn't fail (I just had to hold my probes on the terminals firmly).
    I did also try OpenBK7231N_QIO_1.12.33.bin but it didn't work any better.
    Is there any way to backup the full 2 MB? My backups cut off at ~1.1 MB... Hesitant to try anything that would possibly prevent me from returning it.
  • Safe mode activated after 17 failed boots
    #4 20195154
    lukedashjr
    Managed to make a full 2 MB backup, and flashed your FullFW.bin. However, after doing so, nothing shows up on wifi. It does display a (possibly-correct) temperature and humidity on the LED, though.
    Added after 1 [hours] 18 [minutes]:
    340728aa
    SYS:000000df          0040192c 00000158
    ST:00000000
    J 0x10000
    bk_misc_init_start_type 0 0
    prvHeapInit-start addr:0x4113c0, size:126016
    [Flash]id:0xeb6015
    sctrl_sta_ps_init
    cset:0 0 0 0
    Entering init log...
    Init log done!
    Commands registered!
    bandgap_calm_in_efuse=0x67
    [load]bandgap_calm=0x67->0x27,vddig=4->5
    [FUNC]rwnxl_init
    [bk]tx_txdesc_flush
    [FUNC]intc_init
    [FUNC]calibration_main
    gpio_level=1,txpwr_state=0
                              user define rfcali mode:1
    get rfcali_mode:1
    calibration_main over
                         NO TXPWR_TAB_TAB found in flash
    Load default txpwr for b:0xb0928
    Load default txpwr for g:0xb0936
    fit n20 table with dist:4
    Load default txpwr for n40:0xb0944
    Load default txpwr for ble:0xb17bd
    temp in flash is:350
    xtal in flash is:12
    xtal_cali:12
    --init_xtal = 12
                    [FUNC]ps_init
    [FUNC]func_init_extended OVER!!!
    start_type:0
    Version:
    Initializing TCP/IP stack
    tcp_port:62642
    app_init finished
    Debug:CMD:Adding command loglevel
    Debug:CMD:Adding command logfeature
    Debug:CMD:Adding command logtype
    Debug:CMD:Adding command logdelay
    Debug:CFG:flash vars not initialised - reading
    Debug:CFG:new offset after read 548, boot_count 16, success count 0
    Info:CFG:####### Boot Count 17 #######
    Debug:CFG:new offset 580, boot_count 17, success count 0
    Debug:CFG:new offset after read 580, boot_count 17, success count 0
    Debug:CFG:re-read - offset 580, boot count 17, boot success 0, bootfailures 17
    Info:MAIN:###### safe mode activated - boot failures 17
    Debug:CFG:HAL_Configuration_ReadConfigMemory: read 2016 bytes to 1904640
    Warn:CFG:CFG_InitAndLoad: Config crc or ident mismatch. Default config will be loaded.
    Info:MAIN:Using SSID []
    Info:MAIN:Using Pass []
    Debug:MAIN:Started http tcp server
    Debug:MAIN:started timer
    Info:MAIN:[SAFE] Time 1, free 96296, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 2/38
    Info:MAIN:[SAFE] Time 2, free 96296, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 2/38
    Info:MAIN:[SAFE] Time 3, free 96296, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 2/38
    Info:MAIN:[SAFE] Time 4, free 96296, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 2/38
    temperature_type=2
                      temp_code:28 - adc_code:343 - adc_trend:[13]:350->[14]:340
    Info:MAIN:[SAFE] Time 5, free 96296, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 2/38
    Info:MAIN:no flash configuration, use default
    Info:MAIN:set ip info: 192.168.4.1,255.255.255.0,192.168.4.1
    Info:MAIN:ssid:OpenBK7231N_8C000000  key: mode:0
    hostapd_main_exiting
    hostapd_exit_handler
    hostapd_exit_done
    Soft_AP_start
    [saap]MM_RESET_REQ
    [bk]tx_txdesc_flush
    [saap]ME_CONFIG_REQ
    [saap]ME_CHAN_CONFIG_REQ
    [saap]MM_START_REQ
    hapd_intf_add_vif,type:3, s:0, id:0
    apm start with vif:0
    me_set_ps_disable:840 0 0 1 0 0
    ------beacon_int_set:100 TU
    set_active param 0
                      [msg]APM_STOP_CFM
                                       update_ongoing_1_bcn_update
    vif_idx:0, ch_idx:0, bcmc_idx:1
    enter low level!
    mac c8:47:8c: 0: 0: 1
    leave low level!
    net_wlan_add_netif done!, vif_idx:0
    uap_ip_start
    configuring interface uap (with Static IP)def netif is no ap's netif, sending boardcast or no-subnet ip packets may failed
    sending broadcast_deauth:5
    Info:MAIN:[SAFE] Time 6, free 88048, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:[SAFE] Time 7, free 88048, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:[SAFE] Time 8, free 88048, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:[SAFE] Time 9, free 88048, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    sta: 0, softap: 1, b/g/n
    softap:ssid=OpenBK7231N_8C000000,channel=1,dhcp=1,cipher_type:OPEN
    Info:MAIN:[SAFE] Time 10, free 88048, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:GEN:dhcp=0 ip=0.0.0.0 gate=0.0.0.0 mask=0.0.0.0 mac=00:00:00:00:00:00
    Info:GEN:ip=192.168.4.1,gate=255.255.255.255,mask=255.255.255.0,dns=192.168.4.1
    Info:MAIN:[SAFE] Time 11, free 88048, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:[SAFE] Time 12, free 88048, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    hapd_intf_sta_add:1, vif:0
    rc_init: station_id=0 format_mod=0 pre_type=0 short_gi=0 max_bw=0
        rc_init: nss_max=0 mcs_max=255 r_idx_min=0 r_idx_max=11 no_samples=10
                        sta_idx:0, pm_state:0
    ctrl_port_hdl:1
    Info:MAIN:[SAFE] Time 13, free 87856, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:[SAFE] Time 14, free 87856, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:[SAFE] Time 15, free 87856, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:[SAFE] Time 16, free 87856, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:[SAFE] Time 17, free 87856, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:[SAFE] Time 18, free 87856, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:[SAFE] Time 19, free 87856, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:[SAFE] Time 20, free 87856, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Added after 2 [hours] 6 [minutes]:
    I have come to believe the TuyaMCU is grounding reset/enable after 25-30 seconds.
    Hoping startDriver TuyaMCU might make it behave - but the boot failure count quickly gets high enough for safe mode where this doesn't work :/
    Is there any way to reset the boot failure count?
    Added after 17 [minutes]:
    Re-flashed to clear boot failure count. startDriver TuyaMCU didn't help :(
    Added after 12 [minutes]:
    01ffc 340728aa
    ST:00000000
    J 0x10000
    [Flash]id:0xeb6015
    sctrl_sta_ps_init
    cset:0 0 0 0
    Init log done!
    [FUNC]rwnxl_init
    [bk]tx_txdesc_flush
    [FUNC]intc_init
    get rfcali_mode:1
    xtal in flash is:12
    xtal_cali:12
    --init_xtal = 12
                    [FUNC]ps_init
    start_type:0
    Version:
    tcp_port:62642
    app_init finished
    Debug:CFG:new offset after read 100, boot_count 2, success count 0
    Info:CFG:####### Boot Count 3 #######
    Debug:CFG:new offset 132, boot_count 3, success count 0
    Debug:CFG:new offset after read 132, boot_count 3, success count 0
    Debug:CFG:re-read - offset 132, boot count 3, boot success 0, bootfailures 3
    Debug:CMD:Adding command startDriver
    Debug:CMD:Adding command addRepeatingEvent
    Debug:CMD:Adding command showgpi
    Debug:CMD:Adding command setChannelType
    Debug:CMD:Adding command showChannelValues
    Debug:MAIN:Initialised pins
    Info:MQTT:MQTT_RegisterCallback called for bT obk8C000000/ subT obk8C000000/+/set
    Info:MQTT:MQTT_RegisterCallback called for bT cmnd/obk8C000000/ subT cmnd/obk8C000000/+
    Debug:CMD:Adding command publish
    Debug:MAIN:Initialised other callbacks
    Debug:CMD:Adding command power
    Debug:CMD:Adding command powerStateOnly
    Debug:CMD:Adding command powerAll
    Debug:CMD:Adding command color
    Debug:CMD:Adding command backlog
    Debug:CMD:Adding command exec
    Debug:CMD:Adding command addcmd
    Debug:CMD:Adding command led_dimmer
    Debug:CMD:Adding command led_enableAll
    Debug:CMD:Adding command led_basecolor_rgb
    Debug:CMD:Adding command led_basecolor_rgbcw
    Debug:CMD:Adding command led_temperature
    Debug:CMD:Adding command led_brightnessMult
    Debug:CMD:Adding command led_colorMult
    Debug:CMD:Adding command led_saturation
    Debug:CMD:Adding command led_hue
    Debug:CMD:Adding command sendGet
    Debug:CMD:Adding command SetChannel
    Debug:CMD:Adding command AddChannel
    Debug:CMD:Adding command ClampChannel
    Debug:CMD:Adding command SetPinRole
    Debug:CMD:Adding command SetPinChannel
    Debug:CMD:Adding command GetChannel
    Debug:CMD:Adding command GetReadings
    Debug:CMD:Adding command ShortName
    Debug:CMD:Adding command AddEventHandler
    Debug:CMD:Adding command AddChangeHandler
    Debug:CMD:Adding command listEvents
    Debug:CMD:Adding command restart
    Debug:CMD:Adding command clearConfig
    Debug:CMD:cmd [exec autoexec.bat]
    Debug:CMD:exec autoexec.bat
    Error:CMD:lfs is absent
    Info:MAIN:Time 1, free 94664, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 2/38
    Info:MAIN:Time 2, free 94664, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 2/38
    Info:MAIN:Time 3, free 94664, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 2/38
    Info:MAIN:Time 4, free 94664, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 2/38
    Info:MAIN:Time 5, free 94664, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 2/38
    hostapd_exit_done
    Soft_AP_start
    [saap]MM_RESET_REQ
    [bk]tx_txdesc_flush
    [saap]ME_CONFIG_REQ
    [saap]MM_START_REQ
    set_active param 0
                      [msg]APM_STOP_CFM
    enter low level!
    leave low level!
    uap_ip_start
    temperature_type=2
                      temp_code:29 - adc_code:342 - adc_trend:[13]:350->[14]:340
    Info:MAIN:Time 6, free 86416, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:Time 7, free 86416, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:Time 8, free 86416, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:Time 9, free 86224, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:Time 10, free 86224, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MQTT:mqtt_userName homeassistant
    mqtt_pass qqqqqqqqqq
    mqtt_clientID obk8C000000
    mqtt_host 192.168.0.113:1883
    Info:MQTT:Connect error in mqtt_client_connect - code: -4
    Info:MAIN:Time 11, free 86224, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:Time 12, free 86224, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    Info:MAIN:Time 13, free 86224, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 5/38
    ctrl_port_hdl:1
    Debug:CMD:cmd [startDriver TuyaMCU]
    Debug:CMD:Adding command tuyaMcu_testSendTime
    Debug:CMD:Adding command tuyaMcu_sendCurTime
    Debug:CMD:Adding command uartSendHex
    Debug:CMD:Adding command tuyaMcu_fakeHex
    Debug:CMD:Adding command linkTuyaMCUOutputToChannel
    Debug:CMD:Adding command tuyaMcu_setDimmerRange
    Debug:CMD:Adding command tuyaMcu_sendHeartbeat
    Debug:CMD:Adding command tuyaMcu_sendQueryState
    Debug:CMD:Adding command tuyaMcu_sendProductInformation
    Debug:CMD:Adding command tuyaMcu_sendState
    Debug:CMD:Adding command tuyaMcu_sendMCUConf
    Debug:CMD:Adding command fakeTuyaPacket
    Debug:CMD:Adding command tuyaMcu_setBaudRate
    Info:NTP:Started TuyaMCU.
    Info:MAIN:Time 14, free 57872, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 7/38
    Info:MAIN:Time 15, free 44192, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 8/38
    Debug:CMD:cmd [tuyaMcu_setBaudRate 115200]
    Info:MAIN:Time 16, free 44192, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 8/38
    Info:MAIN:Time 17, free 44192, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 8/38
    Debug:CMD:cmd [tuyaMcu_sendHeartbeat]
    Debug:CMD:cmd [tuyaMcu_sendMCUConf]
    Info:MAIN:Time 18, free 71552, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 6/38
    Info:MAIN:Time 19, free 71568, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 6/38
    Info:MAIN:Time 20, free 71568, MQTT 0, bWifi 0, secondsWithNoPing 0, socks 6/38
    (Skipping tuyaMcu_setBaudRate didn't help)
    Note that explicitly rebooting the device does NOT start the "timer" over - it still dies after 25-30 seconds from the initial boot (not the reboot).
    Added after 29 [minutes]:
    Pressing the button on the device appears to reboot the CB3S.
    I'm wondering if the TuyaMCU is only supposed to power it up "as needed" to report data - I notice it shows the temperature even after/while the CB3S is dead.
    But the paper included with it says it has an "AP Mode" which sounds like it would need the CB3S constantly active...
    (I actually think I'd prefer it to spawn OpenBK only as-needed to report temperature, but I need to get OpenBK configured for that first at least! But I also note that when I _did_ manage to configure my wifi, OpenBK failed to connect saying the password was wrong - it wasn't)
    Added after 35 [minutes]:
    Ok, so the CB3S power comes from R2, which comes from C1 - which I am guessing is a capacitor (sorry, I'm not an electronics person so not sure) that the TuyaMCU charges when it wants to.
    Connecting 3.3V directly to CB3S gets it to survive beyond the 20 seconds.
    "AP mode" is apparently _just_ for setup, and not a persistent AP. So that may not help me either. :/
    Added after 1 [hours] 4 [minutes]:
    Perhaps a bigger issue: I'm not seeing any useful data from TuyaMCU when I have it running.
  • TuyaMCU needs BK7231 to send UART first
    #5 20195500
    Rate: 12973
    Thank you for your research.
    You are correct with TuyaMCU resetting WiFi module.
    I think it would be worthwhile for you to consult those links:
    My considerations and research of similar issue (translated from Polish, not yet finalized):
    https://www.elektroda.com/rtvforum/topic3914412.html
    Tuya docs:
    https://developer.tuya.com/en/docs/iot/tuyacl...niversalserialaccessprotocol?id=K95afs9h4tjjh
    see the diagram above, the TuyaMCU waits 30 seconds for BK7231 to send data on UART first
    This is correct. The WiFi module is supposed to send something first.
    Here is my quick stub of driver for that, not finished:
    https://github.com/openshwprojects/OpenBK7231T_App/blob/main/src/driver/drv_tuyaMCUSensor.c
    There is my very crude way to send data to TuyaMCU after 3 seconds in driver has elapsed:
    Code: C / C++
    but the basics should be working, please consult linked Elektroda topic for details
    Extra Hint: you can change the number of seconds required for boot to be marked as okay in the settings. Change it to lower value if you are getting failed boots all the time.
  • #6 20196391
    lukedashjr
    Any reason to wait 3 seconds? Can I just put these things in an autoexec?
  • tuyaMCU and tmSensor startup setup
    #7 20196499
    Rate: 12973
    The command used in autoexec (or in short startup command) is in the topic I linked before. You start two drivers - tuyaMCU and tmSensor driver. The latter resides on top of tuyaMCu driver and sends packets.
    Regarding 3 seconds... no real reason, I just wanted to let things settle up. It's an experimental setup. I am not sure if it will work for your device. Remember that also you might need to discover dpIds later - which variable ID is temperature, which is humidity, etc. Still, it should be easy, just look at integer values and look at the screen.
    The temperature might be send as integer even if it has fractional part on screen - it's just sending eg. 255 for 25.5C, 199 for 19.9C, etc. I saw that in TH06 temperature sensor, if I remember correctly.
    Remember, this is an experimental setup.some things may be missing, but I can help with implementation if that's needed
  • tmSensor failed and power still cuts sooner
    #8 20196997
    lukedashjr
    tmSensor didn't help at all - I think it may have actually made it kill power sooner :/
    Rigged this, but it also results in power getting killed sooner:
    backlog startDriver tuyaMCU; tuyaMcu_sendProductInformation; addRepeatingEvent 4 999 uartSendHex 55aa00020001040655aa00060008011209111009050159; addRepeatingEvent 4 999 uartSendHex 55aa000a0001000a55aa00050001000655AA00100002010012; ; tuyaMcu_sendQueryState;
  • UART loopback testing to debug TuyaMCU devices
    #9 20197068
    Rate: 12973
    There are many things that can go wrong. Even a different baud ratio for UART is possible.
    What I'd try doing, is disconnecting RX/TX from WiFi module and trying to interface the MCU with PC, sending packets from RealTerm and checking if it responds.
    If you have an original 2MB firmware backup, then it should be also possible to connect RX pin from UART to USB converter to either TX-RX or RX-TX line and watch the communication between MCU an WiFiModule.
    This is the way I use to debug TuyaMCU IoT devices.
  • #10 20197718
    lukedashjr
    Disconnecting things and soldering is beyond my skill. It's the most I can do to hold the probes on the pins to power and flash it. :/
  • #11 20200359
    Rate: 12973
    Ok, then there is an easier option - you just need to make WiFi module powered by 3.3V permanently and just test things in OBK console, see how the MCU responds to queries, etc.
  • #12 20201913
    lukedashjr
    Not sure how to do that without soldering either?
  • #13 20205435
    Rate: 12973
    Then maybe let's go with non-soldering route - restore original flash and then try watching the communication between TuyaMCU module and WiFi module, see what happens on both RX-TX and TX-RX lane. Determine what is being sent by original WiFi module to TuyaMCU so TuyaMCU is not turned off after 30 seconds. See how is the LCD data sent (temperature? date? etc?).
The discussion revolves around issues faced while flashing the OpenBK7231N firmware on a Tuya-based wireless temperature and humidity sensor (CB3S/BK7231N). The user reports that after successfully flashing the firmware, the device crashes shortly after booting, regardless of WiFi configuration. They suspect the firmware size may be an issue, as they can only read a portion of the device's memory. Suggestions from other users include trying older firmware versions, making a full 2MB backup, and using UART for debugging. There are also discussions about the TuyaMCU's role in resetting the WiFi module and the need for proper communication between the MCU and the WiFi module. The user expresses frustration with the device's performance in low temperatures and seeks recommendations for a non-cloud-based, open-source alternative that can operate in freezers.
TL;DR: 30 seconds: "TuyaMCU waits 30 seconds for BK7231 to send data." Send a UART hello quickly, or TuyaMCU cuts power. For BK7231N, a full 2 MB flash plus a lower safe‑mode threshold often stabilizes things. [Elektroda, p.kaczmarek2, post #20195500]
Why it matters: This FAQ helps makers fix CB3S/BK7231N Tuya temp/humidity sensors that crash, lose Wi‑Fi, or power down unexpectedly—without relying on Tuya cloud.
Why does my BK7231N crash or enter safe mode after flashing OpenBK?
Some BK7231N batches have partition layouts that conflict with partial images. Flashing a full 2 MB image overwrites config areas and fixes boot loops. After flashing, set your device’s MAC in settings. If it still reboots, TuyaMCU may be cutting power due to the 30‑second low‑power window. [Elektroda, p.kaczmarek2, post #20185926]
What is the 30‑second shutdown, and how do I stop it?
TuyaMCU runs a low‑power policy and turns off the Wi‑Fi module if it hears nothing on UART. "TuyaMCU waits 30 seconds for BK7231 to send data." Start the TuyaMCU driver and send an initial packet quickly (hello/query) to keep power on. [Elektroda, p.kaczmarek2, post #20195500]
Can I keep the CB3S alive long enough to configure Wi‑Fi?
Yes. Power the CB3S module directly with 3.3 V during setup. Users report the module then survives beyond the usual ~20–30 seconds, allowing AP access and configuration. This is useful before you implement the TuyaMCU UART handshake in firmware. [Elektroda, lukedashjr, post #20195154]
How do I send the TuyaMCU handshake bytes in OpenBK?
How‑To:
  1. startDriver tuyaMCU (optionally also start the tmSensor driver on top of it).
  2. Send hello: 55 AA 00 01 00 00 00, then request state: 55 AA 00 02 00 01 04 06.
  3. After Wi‑Fi or MQTT is up, publish sensor channels. “Basics should be working”; timings can be adjusted. [Elektroda, p.kaczmarek2, post #20195500]
Can I automate the handshake in autoexec instead of waiting?
Yes. Put startup commands in autoexec to start tuyaMCU and the tmSensor driver, and send the initial packets. The prior 3‑second delay was just experimental: "no real reason, I just wanted to let things settle up." Adjust timing as your device needs. [Elektroda, p.kaczmarek2, post #20196499]
Which UART baud rate should I use with TuyaMCU, and how can I find it?
Baud rates vary by device. Identify it by sniffing the original traffic. Disconnect RX/TX from the Wi‑Fi module and talk to TuyaMCU from a PC (e.g., RealTerm). Or place a USB‑UART on the RX/TX lines to watch module–MCU exchanges. "This is the way I use to debug TuyaMCU IoT devices." [Elektroda, p.kaczmarek2, post #20197068]
My backup stops at ~1.1 MB; are OpenBK builds too big, and how do I restore stock?
Use tools that dump the full 2 MB. One report showed reads capped at 1,150,976 bytes, while images were 1,220,464 bytes. For stock restore, decrypt the factory backup with Tuya’s Windows encrypt.exe, then reflash. This preserves your return path if needed. [Elektroda, lukedashjr, post #20185849]
After flashing a full 2 MB image, I see no Wi‑Fi; what should I check?
Review UART logs for SoftAP bring‑up. OpenBK typically starts SSID OpenBK7231N_xxxxxx at 192.168.4.1. If no AP appears, TuyaMCU may be powering the CB3S off; keep it powered with 3.3 V while testing. AP mode is for setup, not persistent operation. [Elektroda, lukedashjr, post #20195154]
How do I reset or avoid the boot‑failure counter that forces safe mode?
Lower the “seconds required for boot OK” value in OpenBK settings so a short window still counts as a successful boot. This prevents safe mode during low‑power cutoffs. Reflashing also clears the counter if needed. Adjust after stabilizing TuyaMCU comms. [Elektroda, p.kaczmarek2, post #20195500]
tmSensor seemed to make shutdowns happen sooner; how do I avoid spamming TuyaMCU?
Reduce UART traffic frequency. Limit repeating events and avoid sending many packets back‑to‑back during the first 30 seconds. A user observed earlier power cuts when tmSensor sent multiple messages rapidly. Start with one hello and one state request. [Elektroda, lukedashjr, post #20196997]
How do I change the MAC address after a full 2 MB flash?
A full‑flash overwrites calibration/config regions, including the MAC. OpenBK lets you set the MAC in settings. After flashing FullFW.bin, update MAC to match the device label to avoid network conflicts. Save and reboot to apply. [Elektroda, p.kaczmarek2, post #20185926]
I can’t solder; any simpler way to test and iterate?
Yes. Keep the Wi‑Fi module powered at 3.3 V permanently while you test commands in the OpenBK console. This avoids the 30‑second cutoff while you dial in the TuyaMCU packet timing and mappings. Revert to normal power once stable. [Elektroda, p.kaczmarek2, post #20200359]
How can I learn the exact packets my device needs?
Restore the original flash, then monitor UART between the TuyaMCU and Wi‑Fi module with a USB‑UART adapter and a terminal tool. Capture the keepalive and data frames that prevent shutdown and drive the LCD. Replicate them in OpenBK. [Elektroda, p.kaczmarek2, post #20205435]
Whats a non-cloud, battery sensor that works in a freezer?
Consider RuuviTag. It runs open firmware, integrates locally over BLE, and is rated for approx. −40 to +85°C on a coin cell. This fits freezer use without cloud dependency. Pair with Home Assistant via BLE for dashboards and alerts. [Ruuvi, 2023]
