How to Update from Kickstart to OpenBK7231N on Temp/Humidity Sensors for HomeAssistant
vnani 1704 5
  • #1 20946916
    vnani
    Hi everyone, I was stupid enough to flash kickstart-bk7231n on these temperature and humidity sensors instead of OpenBK7231.
    I would need help in writing YAML code in HomeAssistant to make this work again.
    It will be powered by 3.3v from the PC motherboard, so power consumption is not an issue.
    Thanks.
  • #2 20946958
    sirhcsat
    Did you flash via serial connection? If so, just reconnect the serial bus to the programmer and reflash the latest OpenBeken firmware.
  • #3 20946960
    vnani
    Nop, I used OTA cloudcutter..
  • Serial flashing recommended if cloudcutter fails
    #4 20946976
    sirhcsat
    I have never used cloudcutter as I never found a device that it worked with once Tuya closed the loopholes in the firmware. Could you not use cloudcutter to reflash again or is it a one-time process? The simple and easy option is to flash by serial with a cheap USB to serial converter, but if you do not have one, then you will need to hope someone else can help you with the YAML or how you could get it working.
    Sorry, I could not help you out.
    Rate: 12954
    I'm sorry for your loss, but don't worry, you can still recover with files from here:
    https://github.com/BenJamesAndo/OpenBeken_uf2_firmware
  • Cannot re-enter AP mode after OTA flash
    #6 21569049
    guycaluwaerts
    I also flashed the kickstart-bk7231n to a mini smart switch with tuya-cloudcutter OTA.
    I can see the device in my router, which means the switch is online. Now I have tried to flash the correct file to the switch, but I cannot put the switch in AP mode anymore. So the switch is not accessible anymore.
    How can I push the switch in AP mode again because pushing the internal and external switches gives no reaction.
