How to add a sensor in Domoticz with X,Y,Z,dir data from ESPEasy?
Ognik69 924 3
  • Creating a four-value virtual sensor in Domoticz
    #1 21006632
    Ognik69
    I need to add a new virtual sensor in Domoticz (Create Virtual Sensor, give name and checkbox). Unfortunately in the sensor set there is only one Custom Sensor to create with single data. I need to create a sensor with quadruple data under one IDX. Similar to how it is with Temp+Wilg+Baro, only with different data. Specifically I want to download from ESPEasy, sensor HMC5883 quadrupole X,Y,Z,dir.
    Does anyone know how to define and add such a sensor?
  • #3 21007995
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    It can't be done. Domoticz is limited by its logical structure, which was not thought through at the very beginning of its existence.
  • #4 21016219
    Ognik69
    So what would you recommend? Migration to HA? Is it possible to transfer the data from the sensors? I would not want to lose the temperature statistics from 5 years
