Hilti C 4/36-350 Charger Stops Charging After 10 Seconds with Battery Inserted
busrevi 4053 8
  • #1 21041354
    busrevi
    hello, my hilti (c 4/36-350) charger stops charging 10 seconds after inserting the battery. Do you have any idea why this happens?
  • #3 21042409
    busrevi
    Battery intact, tested with another charger
  • #4 21256912
    keklikozcan
    Rate: 8
    Hi did anyone solve this problem? I replaced L6599AD IC and MIP2M2 IC but same. Relay, triac, MOSFETs, all zener diodes good. Battery is good. Anyone can help me?
  • #5 21336813
    slymnshn1981
    How did you solve this error? Can you explain with pictures?
  • #6 21385358
    yoramr7
    Hi did anyone solve this problem ?
  • #7 21812409
    audiovideo416
    @busrevi, have you solved it? I have the same problem.
  • #8 21904430
    yandigulumpostane
    any one solved this? pls need help.
  • #9 21909706
    audiovideo416
    >>21904430 When this problem occurs, the culprit is the microprocessor, which cannot be replaced because it must be programmed with the official firmware, which is not available online.
The Hilti C 4/36-350 charger stops charging about 10 seconds after a battery is inserted. The battery was confirmed to be good by testing it on another charger. Later replies suggest troubleshooting the charger’s power/control section, including replacement checks of the L6599AD and MIP2M2 ICs, relay, triac, MOSFETs, and zener diodes, but the fault remained unresolved. The final diagnosis states that the likely cause is a defective microprocessor, which cannot be easily replaced because it requires official firmware that is not available online.
