How do I add days to the Rain Bird ESP-RZXe schedule?
knorbert94 1560 1
  • Missing watering-day selection in scheduler
    #1 21043435
    knorbert94
    I have a problem with the Rain Bird ESP-RZXe controller in that I am unable to add two zones to the watering schedule. I can set the watering times for them in the Scheduler, the times at which they should switch on, but I cannot select the days, which means the zone does not switch on in automatic mode. It doesn't go to the option to select watering days at all.
    I can start them in manual mode.
  • #2 21213891
    36Balu
    I have the same problem.
    How did you manage to fix the issue?
    Added after 36 [minutes]:
    I already know!
    As the -:- flashes, press NEXT once and then hold down (very long ) the minus button until the icons that are in the instructions appear.
