Creating a scene in Tuya: Door sensor and LED dimmer switch - message error
lorcykluk 1107 1
  • Tuya scene trigger fails on door open event
    #1 21051647
    lorcykluk
    I have a problem with a scene;
    I have a wifi door open/close sensor with tuya
    A switch with dimmer for led also tuya
    I have added the devices to the app without problem and everything works fine.
    The problem starts when I want to create a scene that in case of opening the door the light should turn on for 1 min.
    A message appears in case of opening the door:
    Terenie is a yes in entrance That failed to trigger
  • #2 21051675
    Rate: 12794
    I guess autocorrect changed the content of this message for you, can you provide it again or post a screenshot of this message?
    Both devices are visible in the Tuya app, both have coverage, etc, the status of both devices is visible?
