Modifying Parkside PLG 20 A1 Charger for Continuous Operation with Converted Batteries
karol_88 3585 5
  • #1 21138829
    karol_88
    Does anyone know what the IC signed OBRC is (six-legged in SMD)
    Close-up of a circuit board with a six-pin integrated circuit labeled OBRC. .
    rtesadfg56
    Help: 141
    Rate: 255
    OB2263, check that everything fits.
  • Missing R18 and unclear output pin on charger board
    #3 21140102
    karol_88
    That's right! The voltage on the pins from the power supply is 14.5V. In the catalogue note it says it should be between 10V and 30V so it is rather good. I only have two more problems:
    - in the data sheet on the circuit diagram it says that on pin 3 there should be a 100k resistor routed to ground but the problem is that on the board there is none 😆. That is, there is a place for the resistor signed R18 but there is no resistor itself, and 100% it was not soldered out.
    - which pin is the output
  • #6 21140288
    karol_88
    It appears to be a replacement. The pinout and schematic are identical
    Added after 15 [minutes]:
    Can the voltage on FB pin 2 0.8V be ? ( this is the voltage that determines the PWM duty cycle
