How do I split the sensors from ESPHome into two cards in Home Assistant?
Honsu 486 0
  • Split ESPHome sensors into two Home Assistant devices
    #1 21145949
    Honsu
    I have an esphome hooked up to a Home assistant.
    The esphome connects via 2 of its rs to two devices.
    I now have entities detected in HA in three fields
    Control
    Sensors
    Configuration.
    The trouble is that in the sensor field I have entities from 2 devices mixed together. Is it possible to set this up in esphome so that the sensors are split into two cards depending on which one I assign it to.
    Added after 3 [hours] 18 [minutes]: .
    Maybe it is possible to configure esphome so that it is seen as 2 separate devices in HA.
