Home Assistant entity data to ESP32 via WiFi for RS485 HMI display integration
Tarnus 1818 2
  • Need a Home Assistant-to-ESP32 entity transfer method
    #1 21533781
    Tarnus
    Rate: 97
    I have mounted a Chinese HMI display next to the inverter, which has two RS485 ports. I set the first port as master and I download data from the photovoltaic inverter via this route. The HMI displays these downloaded parameters. I set the second port on the HMI as a slave. This port is connected to an ESP32 with WiFi activated. The Home Assistant connects over WiFi to this ESP32 and downloads the inverter parameters available to the HMI. I would also like to display some relevant parameters from the heat pump and other devices in the house on this same HMI. The pump sends its parameters to the HA via a second ESP32, also running WiFi. Currently I already have several of these ESP32s and more will be coming. This is where I have a problem. I cannot in any way send the value of any entity from the HA to this ESP32, which is connected with the HMI. How do I bite into this? How do I send the value of any entity from the HA to the ESP32? I send from ESP32 as master to slave HMI seamlessly, but not from HA to ESP32. It looks like this, as if the entity in the HMI is a global value.
  • #2 21534533
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    And what do you have on this ESP32? EspHome? Tasmota? Or some code of your own?
  • ESPHome template sensor writes Home Assistant value to Modbus register
    #3 21535194
    Tarnus
    Rate: 97
    >>21534533 I was just about to write that I managed to solve the problem. The answer to your question is that all the ESP32s I have are from ESPHome.
    Below are excerpts from the script responsible for getting the entity value from HA and sending it to the modbus slave using ESP. I have tried a number of ways. There may be other/better solutions, I'd be happy to hear about them. For now, the important thing is that the one below works:
    captive_portal:
    uart:
    tx_pin: 17
    rx_pin: 16
    baud_rate: 9600
    stop_bits: 1
    modbus:
    send_wait_time: 200ms
    modbus_controller:
    - id: "${devicename}"
    address: 0x1
    modbus_id: solar_hmi_modbus
    setup_priority: -10
    update_interval: 10s
    sensor:
    - platform: homeassistant
    entity_id: sensor.counter_inflation
    - platform: template
    internal: true
    lambda: |-
    uint16_t value = id(${devicename}_test_count_test).state;
    esphome::modbus_controller::ModbusCommandItem set_payload_command = esphome::modbus_controller::ModbusCommandItem::create_write_single_command(${devicename}, 0x96, value);
    ${devicename}->queue_command(set_payload_command);
    return {};
