How to connect W5500, RC522, reed switches to ESP32 in ESPHome (Home Assistant)?
iwnuk22 1305 1
  • Shared SPI wiring for W5500 and RC522 on ESP32
    #1 21503614
    iwnuk22
    listen i have a problem, because i want to create such a sensor that if the door is opened and the card is not bounced, something will happen there in home asistant, but what i mean is, how to connect it? and the signal will be sent over the internet via internet cable and i want to create it with w5500, rc522 and 3 reed switches and all this i want to connect under esp32 and have it work in esphome (HA).
    AI: How do you plan to connect the W5500, RC522 and reed switches to the ESP32? Do you already have a wiring diagram?
    W5500 → ESP32
    SCK → GPIO18
    MISO → GPIO19
    MOSI → GPIO23
    CS → GPIO15
    RST → GPIO2
    VCC → 5V
    GND → GND
    RC522 → ESP32
    SCK → GPIO18
    MISO → GPIO19
    MOSI → GPIO23
    CS (SDA) → GPIO5
    RST → GPIO4
    VCC → 3.3V
    GND → GND
    AI: Do you already have any settings configured in ESPHome for these devices? If so, which ones?
    not something I tried, but the same errors kept popping up
  • #2 21504889
    Rate: 12898
    What errors were popping up? It looks like you will need to use a binary sensor:
    https://esphome.io/components/binary_sensor/gpio.html
