How to Amplify Signal for Tuya Smart Home Gate Module with Extended Cable Length?
gruniu78 504 1
  • Longer cable likely causing contact voltage drop
    #1 21156143
    gruniu78
    Level 4  
    I have a device at home here. Everything is laughing.
    But the module from the gate control has a problem with the length of the cable to the contract.
    The module is in the wifi range and at its limit. Also moving the module closer to the contract will result in no wifi.
    The cable to the contract is about 1m longer than the manufacturer gave and this is the problem. It often shows that the gateway is open but it is closed.
    Through which I get messages that the gate is open and the outside lights are on - because that is my configuration.
    How do I amplify the voltage on the contract, because I think this is the problem?
    Photo of the module inside, I will send later.
  • Use a transistor switch for the reed contact
    #2 21156156
