Controller ERO-32WS-0: How do I delay turning off the fan when the light goes out?
Dominias 645 2
  • Requesting a delayed fan-off command
    #1 21182975
    Dominias
    I have a wifi controller for a chimney fan type ERO-32WS-0 (wlightboxS) and I wanted to do something like this so that when the light is on, the fan turns on and when it is off, the fan turns off. I managed to do this but would like to delay the switch off by a set amount of time. Does anyone know of a command that delays the switch off by a set amount of time?
    Thank you in advance for your help
  • #2 21183315
    sosarek
    Help: 9320
    Rate: 15541
    To start with, draw out what and how you have connected by adding the make and model of the fan.
    Z
    Pka, Poznań, 60-850
  • #3 21183929
    Dominias
    I have control done via blebox relays to the switchbox light, and to the fan in the lightbox s. The control for the fan is ERO032WS-0. I did the switching on and off of the fan using the action in the switchbox light.
