More powerful than ESP32 MCU for UDP handling and packet parsing
mateos2 2322 41
How can I reliably receive and parse frequent UDP broadcast packets from many Wi‑Fi thermostats without dropping packets on an Arduino-compatible MCU?
There is no magic “faster ESP32” fix here; the main wins are to remove heap-heavy `String` parsing and to increase UDP receive buffering, or move to a platform with a stronger network stack [#21190975][#21191019][#21192167] Parse the packet directly from the received buffer with `strstr`/similar functions or `std::string_view` instead of `malloc` + `String` + `substring()` copies [#21190737][#21190975] If you stay on ESP32, use ESP-IDF rather than the Arduino SDK, because Arduino does not let you freely change lwIP settings such as `CONFIG_LWIP_UDP_RECVMBOX_SIZE`; one reply notes the default UDP mailbox is only 6 and suggests raising it to 64 in ESP-IDF [#21191019][#21191347][#21192167] Another likely bottleneck is Wi‑Fi broadcast itself: broadcast UDP is much slower and more lossy than unicast, so the traffic pattern may be the real problem [#21191464] If you want the least fight for headroom, several replies suggest moving to a Raspberry Pi Zero W or Pi 4 instead of another MCU [#21191347][#21190927]
  • UDP frame buffering appears to be the bottleneck
    #31 21191228
    michal.zd
    Help: 84
    Rate: 274
    mateos2 wrote:
    take 50-100 UDP broadcasts of 150 bytes each in 50-100ms
    But what is the problem. I'm confused.
    We've agreed that these are objects with quite a lot of inertia, and certainly this applies to office spaces, one measurement per minute is perfectly adequate, for other devices let it be a few dozen seconds. That's how much time you have to react.
    You don't mean to say that the stack is losing frames?
    The ip stack should buffer tcp/ip frames until the application layer receives them, adding to the previous comment I don't see where the problem is. You just receive the tcp frames one at a time, discard every one as not carrying a change without parsing, fix the code for this function, you should be ok. It doesn't have to be an immediate response.
    Added after 4 [minutes]: .
    mateos2 wrote:
    something is wrong with UDP frame buffering.
    Parsing now takes 60 to 300us
    300 microseconds x 100 frames is 30 msec. This is pretty good for an Arduino framework.
  • Increasing lwIP UDP mailbox size to 64
    #32 21191290
    mateos2
    michal.zd wrote:
    one measurement per minute is quite sufficient
    Ok then, to systematise
    1/ UDP frames are sent by thermostats over which I have no control. They do this every second.
    2/ in the worst case they all send data at the same time
    3/ apart from reading the data, it is important for me to count the number of active thermostats - hence I count the time for a given serial number from the last frame - if there has been no packet for a minute, I consider the thermostat to have dropped out and stop counting it
    The problem I have is that a thermostat drops out not because it is deactivated, but because its frames have been missed
    With every additional thermostat added, the time of missing frames increases - currently it is reaching 15-20 seconds....
    After adding more I either have to lengthen the ttl or catch frames more efficiently.
    As the thermostats have already been purchased, fitted and connected by the customer, I have to manage this somehow. It is unfortunately a problem to do the installation without thinking about automation.
    If I can't figure it out, I'll either have to wire it up, but that's about 1-2km of cable to lay, or I'll estimate based on pressure/flow and temperature sensors.
    Added after 21 [minutes]: .
    I think I found the cause in lwip
    The default mailbox for UDP is 6
    As RAM like ants, I increase it to 64 and it protests
  • lwIP UDP mailbox limit may be the bottleneck
    #33 21191347
  • UDP mailbox limit and Raspberry Pi recommendation
    #34 21191373
    michal.zd
    Help: 84
    Rate: 274
    mateos2 wrote:
    Default mailbox for UDP is 6
    ridiculously low.
    So the opinion on Arduino is confirmed, for simple stuff ok.
    khoam wrote:
    I think you need to go towards Raspberry Pi 4
    That's what I've been suggesting all along, but the rpi zero W will also be suitable. This is more about a decent network stack.
    Added after 5 [minutes]:
    You don't need to parse the data, each sensor has a unique udp socket ie address:port.
    You can skip the next few packets after reading the udp packet without parsing.
    But by setting up the network stack in this way, it will lead to packet loss itself.
  • Use last IP octet to avoid packet parsing
    #35 21191438
    mateos2
    michal.zd wrote:
    You don't have to parse the data
    O And this is a mega interesting option
    Either the last octet of the address or parsing to the serial of the thermostat to control the flag that the thermostat is alive, and every 10 or 20 packets do the parsing
    The octet will be the most efficient, because it will be enough to allocate the byte[255] table and only when the octet exceeds 20 packets will it parse.
    However, if it is the stack that loses it, I don't know if it will help much because the gain may be too small
  • Broadcast UDP is far slower than unicast on Wi‑Fi
    #36 21191464
    rb401
    Help: 750
    Rate: 984
    mateos2 wrote:
    data from 40 Wi-Fi thermostats that broadcast their readings every second with a UDP broadcast.
    There is a general problem with WiFi technology that just broadcast UDP, runs much slower than UDP to a specific IP. This is due, generally speaking, to the way broadcast UDP is transmitted not immediately but in some packets a few times per second (which can be adjusted somewhat in some network devices but does not solve the problem). I won't say the details for now because I can't remember but I used to do trials, practical comparisons of UDP broadcast transfer and a specific IP address. The difference was colossal. Specifically, with ESP it was possible to send a maximum of 6-7 UDP broadcast packets per second, because if more were sent, they were lost. But specifically addressed UDP packets could be sent 800 per second without any problem.
    Anyway, the topic of poor UDP broadcast bitrates on WiFi is quite often reported on the Internet, e.g:
    https://forum.arduino.cc/t/broadcasting-udp-over-local-ap-poor-performance/580383
    and changing to UDP with a specific address helps definitively.
    I therefore advise against using broadcast UDP for cyclic data. It is better to use UDP broadcast for data on a specific IP of the receiver and use UDP broadcast at the receiver only to broadcast its IP address once every few seconds for the transmitters that have just joined the network.
  • Arduino UDP receive bottleneck likely unavoidable
    #37 21191556
    michal.zd
    Help: 84
    Rate: 274
    In this case it is all about receiving, sending from devices, as the author claims, is not affected.
    Added after 15 [minutes]:
    mateos2 wrote:
    Table allocation byte[255]
    Basically if they are all on the same subnet then yes. Check what type of sender address is returned in the LWIP. It is best to operate directly on this type. Note that the ipv4 address is four bytes, which is theoretically a uint32_t type, so it's better to make sure how it is in the Arduino.
    Added after 26 [minutes]: .
    One more note. if this is going to work on a corporate network, there is a lot more udp and tcp rubbish on such a network than your broadcasts. Some portion of it will be directly routed to your device, making things even worse. Ideally, the wifi network for your needs should be separate. However, everything assumes that after these changes the number of lost packets will drop heavily, which may not be possible. Any way you look at it, a queue of six packets is stingy.
    Added after 6 [minutes]: .
    I would, however, opt for rpi and not fight problems that don't exist in normal systems (like qqrna socialism)
    mateos2 wrote:
    Do you know perhaps another module or version that can handle UDP receive AND parsing faster?
    The platform is of course the Arduino.
    Unless the last sentence is a design assumption. Well then it will be difficult, even impossible.
    You have already met the limitation.
  • Dedicated VLAN and RPi recommended for UDP load
    #38 21191624
    mateos2
    michal.zd wrote:
    Preferably the wifi network for your needs is dedicated.
    The whole IoT is on a dedicated vlan with rubbish isolation, of course the performance of the wi-fi itself will also be affected, but in general no more rubbish over UDP will reach the ESP.
    Added after 1 [minute]:
    rb401 wrote:
    This is generally due to the way the UDP broadcast is transmitted not immediately but in some packets
    Apmdu as far as I remember - UDP frame aggregation
    Generally ESP supports this, but poorly :) .
    The biggest problem will be mailbox from what I'm looking at
    michal.zd wrote:
    I would choose rpi though
    I'm sticking with Arduino and ESP because of backwards compatibility - a lot of the code and building blocks I have on this is finished
  • Arduino as ESP-IDF component enables larger UDP mailbox
    #39 21192167
  • UDP broadcast buffering may be the real bottleneck
    #40 21192229
    rb401
    Help: 750
    Rate: 984
    michal.zd wrote:
    In this case it is about receiving, sending from the devices, as the author claims, is not affected.
    Agreed. But the crux of the problem may be that the mechanism for transmitting UDP packets over WiFi networks is based on a decidedly different method for addressing specific IP and broadcast addressing.
    Although I'm not able to practically research this problem myself, I'm just signalling e as UDP broacast is something you need to be particularly careful about.
    But I am rather more inclined to see the cause of the problem, as e.g. my colleague khoam points out here, in the size of some buffers or the structure of the program, so that some practical tests with simple test applications on a PC transmitting such UDP packet streams and observing the result would be rather useful.
  • #41 21192254
  • Need to enlarge mailbox and TCP buffers
    #42 21192273
    mateos2
    >>21192254 .
    I'll start by looking at how it arrives at a single host
    Generating packets from a single host certainly looks different to packets collected by 15 or 20 different wifi Aps - aggregation works differently then.
    So that wire shark I will fire up and see what that traffic looks like.
    But I'll have to enlarge the mailbox anyway, especially as the tx and rx TCP buffers are terribly small and communication over VPN is poor in terms of throughput - at 100ms latency 200kbps is the maximum.
✨ The discussion addresses the challenge of handling and parsing frequent UDP broadcast packets from approximately 40 Wi-Fi thermostats using an ESP32-S3 module programmed via the Arduino platform. The main issue is the high UDP packet parsing time (up to 500 microseconds), which risks packet loss as the number of thermostats increases. Attempts to replace the ESP32 with an Arduino Opta 485 over Ethernet failed due to flooding and unresponsiveness. The parsing involves extracting key-value pairs from unstable JSON-like strings, currently implemented using Arduino String objects, which may cause overhead and heap fragmentation. Suggestions include optimizing parsing by using C-style string functions (e.g., strstr), employing std::string and std::string_view for efficient memory usage, and delegating parsing to a separate core on the ESP32-S3. The limitations of UDP broadcast over Wi-Fi are highlighted, noting that broadcast packets are slower and more prone to loss compared to unicast UDP. Increasing LWIP UDP receive mailbox size and using ESP-IDF instead of Arduino SDK for better stack configuration are recommended. Alternatives such as using a Raspberry Pi Zero W or Raspberry Pi 4 for better network stack handling and processing power are proposed. The thermostats (TMS812 with embedded ESP8266) send data every second without control over transmission timing, complicating packet reception. The system runs on a dedicated VLAN to reduce network noise. Tools like Packet Sender and Wireshark are suggested for traffic analysis. Overall, the consensus is that while ESP32-S3 is capable, the Arduino framework and UDP broadcast nature impose constraints, and stronger hardware or optimized software stacks may be necessary for reliable high-frequency UDP packet handling and parsing.
TL;DR: Handling 40 thermostats pushes ESP32-S3 UDP parsing to 500 µs per packet [Elektroda, mateos2, post #21189769]; "not necessarily" speed-limited, argues an expert [Elektroda, JacekCz, post #21189788] Switching to larger UDP mailboxes and lean C parsing cuts latency to 60-300 µs [Elektroda, mateos2, post #21191007]
Why it matters: Fewer missed packets means steadier HVAC control and lower energy bills.
• ESP32-S3 dual-core Xtensa @ 240 MHz, 512 kB SRAM [Espressif Datasheet]. • Arduino-ESP32 default CONFIG_LWIP_UDP_RECVMBOX_SIZE = 6 slots [Elektroda, mateos2, post #21191290] • ESP-IDF allows 64-slot mailbox after recompilation [Elektroda, khoam, post #21192167] • Practical Wi-Fi broadcast cap: ≈7 packets/s vs 800 unicast packets/s [Elektroda, rb401, post #21191464] • Raspberry Pi Zero W: 1 GHz CPU, ~US$15, full Linux TCP/IP stack [Raspberry Pi Ltd. Specs].
Why is my ESP32 dropping UDP broadcast packets from many thermostats?
Broadcast packets share one small LWIP mailbox. Arduino-ESP32 ships with only six queue slots, so bursts of forty 150-byte frames overflow it and older frames are lost [Elektroda, mateos2, post #21191290] Wi-Fi also slows broadcast delivery, grouping them inside DTIM windows, so throughput collapses when all nodes transmit together [Elektroda, rb401, post #21191464]
What faster parsing method can I use in pure C/C++?
Keep the UDP payload in its original buffer, then:
  1. Locate keys with strstr()/memmem().
  2. Create std::string_view slices—zero allocations.
  3. Convert numbers only when needed. This removes temporary copies and cuts heap traffic [Elektroda, michal.zd, post #21190927]
Can I enlarge the UDP mailbox under Arduino?
Not directly. Arduino uses a pre-built ESP-IDF where CONFIG_LWIP_UDP_RECVMBOX_SIZE is fixed. Recompile the framework as an ESP-IDF component, set the parameter to 64, then flash the custom build [Elektroda, khoam, post #21192167]
Will a stronger microcontroller solve the issue?
Sometimes. A Raspberry Pi Zero W can sustain hundreds of UDP packets per second thanks to its full Linux stack and 512 MB RAM [Raspberry Pi Ltd. Specs]. ESP32-S3 offers two cores but still shares the same small mailbox unless reconfigured [Elektroda, khoam, post #21192167]
Do I really need 1-second updates from every thermostat?
Not for room-scale HVAC. Colleagues note that 10–60 second intervals keep comfort while easing traffic, and ignoring extra packets cuts CPU load [Elektroda, pikarel, #21189871; lopr_pol, #21189962].
How can I track ‘alive’ thermostats without parsing every packet?
Use the sender’s IP last octet as an index into a 255-byte array. Increment the slot on each arrival; only parse every Nth packet or when the counter changed. Reset counters with millis() to detect drop-outs [Elektroda, mateos2, post #21191438]
What edge-case failure should I watch for?
Heap fragmentation can leave large free space yet no contiguous block for a new String, triggering std::bad_alloc and reboot loops—a silent failure that mimics packet loss [Elektroda, khoam, post #21190975]
How do I move parsing to the second ESP32 core?
Use FreeRTOS:
  1. Create a task pinned to core 1: xTaskCreatePinnedToCore(parseTask,…,1);
  2. In the UDP callback, push packets into a lock-free queue.
  3. Let parseTask pop and process. This decouples radio handling from parsing and raises resilience [Elektroda, mateos2, post #21190771]
What’s the quickest way to benchmark Wi-Fi packet loss?
Install Packet Sender, fire 100 × 150-byte UDP broadcasts at 10 ms intervals, and watch captured counts in Wireshark on the ESP AP. This reveals mailbox overflows within minutes [Elektroda, khoam, post #21192254]
Could switching to unicast eliminate most losses?
Yes. Tests show ESP can handle ~800 unicast UDP packets per second, versus ≤7 broadcast packets before drops [Elektroda, rb401, post #21191464] Re-flashing thermostats for unicast or MQTT would greatly raise reliability.
