Wiring SUPLA ROw-2 to Control Two Lamps with a Two-Key Switch and WiFi
Lakol 624 1
  • #1 21276503
    Lakol
    Maybe it's already been on the forum somewhere, but I can't find it.
    I have an exterior light in the form of two lamps. They are switched on from one two-key switch, each separately.
    How can I connect the SUPLA ROW-2 to this so that the WIFI cable can also be switched on and off?
    Can anyone draw up a diagram?
  • #2 21276841
    Rate: 12856
    If I have understood you correctly, there should be no problem. There is a diagram for this in the ROW-2 manual:
    Wiring SUPLA ROw-2 to Control Two Lamps with a Two-Key Switch and WiFi .
