[Solved] ESP32-WROOM-32: Problems uploading ESPeasy, how to install correctly?
Szaryczlowiek83 1188 3
  • Use the ESP32_4M316k-factory.bin after erasing flash
    #1 21291035
    Szaryczlowiek83
    Help!!!
    I've been craving a thermometer on my esp32 and I've been sitting and fiddling for 3 hours because it won't work.
    Maybe I'm too stupid!!!?
    I acquired the esp32-wrom board from the link below
    Plate .
    I wanted to upload espeasy as I have some experience with it.
    The problem is that whatever I do and whatever I upload, the board doesn't want to be created.
    I downloaded the espeasy_mega_20240822_esp32 whole package and according to the guide I should upload the ESP32_4M316k-factory.bin version
    The guide is: Guide .
    I had previously read that you should erase the memory before uploading the new .bin when connecting the board to USB, although my screen flashed. After erasing I don't know if the board is alive. After winning the .bin I got the message:
    ESP32-WROOM-32: Problems uploading ESPeasy, how to install correctly? .
    Please advise me as if I am a retard
    madamsz1
    Help: 1057
    Rate: 1711
    I don't know what you are uploading there, but do you have the address listed ? - I don't see anything like 0x00000 deep in there
    You could try NodeMCU-PyFlasher
  • #3 21291183
    Szaryczlowiek83
    madamsz1 wrote:
    I don't know what you are uploading there, but do you have the address given? - I don't see anything like 0x00000 deep in there
    The window obfuscated, that's how the address was entered.
    I don't know by what miracle, but I managed to upload the display version via web flasher.
    So that topic is closed, thanks for your help.
  • #4 21291185
    Szaryczlowiek83
    I managed to solve the problem with web tools.
