What is the wifi antenna - flashing the Nous A1
interim 480 0
  • Antenna patch identification and replacement question
    #1 21334871
    interim
    I'm doing a flash of Nous A1 wifi plugins (not zigbee, not tasmota). The subject would be trouble free if it weren't for:
    - the location of TX, RX, GND on the bottom side of the board, which forces its removal
    - the way the wifi antenna is mounted, which rubs very easily when removed.
    In the attached photo, the cable is connected to a patch like this. What is this and where to get it? Or will the wifi work without the tracks on the patch (antenna cable alone). Interior of a Nous device with connected antenna cable and visible circuit board. .
    This is glued firmly to the chassis and removal for flashing is virtually impossible without trying to peel it off (with varying results).
