Apator integration error with Home Assistant - CC1101 connection problem
xavier666 1788 1
  • Need CC1101 wiring and configuration details
    #1 21356029
    xavier666
    Good morning everyone.
    I have the following problem.
    I am in the process of integrating the Apator water meter overlay into Home Assistant.
    I have used the tutorial from the link below
    and everything went ok, but after running it I get the following error
    INFO ESPHome 2024.12.1
    INFO Reading configuration /config/esphome/licznik-wody.yaml...
    INFO Detected timezone 'Europe/Warsaw'
    INFO Starting log output from 10.0.0.190 using esphome API
    INFO Successfully connected to licznik-wody @ 10.0.0.190 in 0.034s
    INFO Successful handshake with licznik-wody @ 10.0.0.190 in 2.714s
    [11:31:19][I][app:100]: ESPHome version 2024.12.1 compiled on Dec 19 2024, 13:20:49
    [11:31:19][C][wifi:600]: WiFi:
    [11:31:19][C][wifi:428]:   Local MAC: 48:55:19:EC:4A:0E
    [11:31:19][C][wifi:433]:   SSID: [redacted]
    [11:31:19][C][wifi:436]:   IP Address: 10.0.0.190
    [11:31:19][C][wifi:439]:   BSSID: [redacted]
    [11:31:19][C][wifi:441]:   Hostname: 'licznik-wody'
    [11:31:19][C][wifi:443]:   Signal strength: -54 dB ▂▄▆█
    [11:31:19][C][wifi:447]:   Channel: 2
    [11:31:19][C][wifi:448]:   Subnet: 255.0.0.0
    [11:31:19][C][wifi:449]:   Gateway: 10.0.0.1
    [11:31:19][C][wifi:450]:   DNS1: 0.0.0.0
    [11:31:19][C][wifi:451]:   DNS2: 0.0.0.0
    [11:31:19][C][logger:185]: Logger:
    [11:31:19][C][logger:186]:   Level: DEBUG
    [11:31:19][C][logger:188]:   Log Baud Rate: 115200
    [11:31:19][C][logger:189]:   Hardware UART: UART0
    [11:31:19][C][captive_portal:089]: Captive Portal:
    [11:31:19][C][sntp:042]: SNTP Time:
    [11:31:19][C][sntp:045]:   Server 0: '0.pool.ntp.org'
    [11:31:19][C][sntp:045]:   Server 1: '1.pool.ntp.org'
    [11:31:19][C][sntp:045]:   Server 2: '2.pool.ntp.org'
    [11:31:19][C][mdns:116]: mDNS:
    [11:31:19][C][mdns:117]:   Hostname: licznik-wody
    [11:31:19][C][esphome.ota:073]: Over-The-Air updates:
    [11:31:19][C][esphome.ota:074]:   Address: 10.0.0.190:8266
    [11:31:19][C][esphome.ota:075]:   Version: 2
    [11:31:19][C][esphome.ota:078]:   Password configured
    [11:31:19][C][safe_mode:018]: Safe Mode:
    [11:31:19][C][safe_mode:019]:   Boot considered successful after 60 seconds
    [11:31:19][C][safe_mode:021]:   Invoke after 10 boot attempts
    [11:31:19][C][safe_mode:022]:   Remain in safe mode for 300 seconds
    [11:31:19][C][api:140]: API Server:
    [11:31:19][C][api:141]:   Address: 10.0.0.190:6053
    [11:31:19][C][api:143]:   Using noise encryption: YES
    [11:31:19][C][wmbus:372]: wM-Bus v3.2.3:
    [11:31:19][C][wmbus:389]:   CC1101 frequency: 868.950 MHz
    [11:31:19][C][wmbus:390]:   CC1101 SPI bus:
    [11:31:19][C][wmbus:391]:     MOSI Pin: GPIO13
    [11:31:19][C][wmbus:392]:     MISO Pin: GPIO12
    [11:31:19][C][wmbus:393]:     CLK Pin:  GPIO14
    [11:31:19][C][wmbus:394]:     CS Pin:   GPIO2
    [11:31:19][C][wmbus:395]:     GDO0 Pin: GPIO5
    [11:31:19][C][wmbus:396]:     GDO2 Pin: GPIO4
    [11:31:19][E][wmbus:409]:   Check connection to CC1101!
    [11:31:19][E][component:082]:   Component wmbus is marked FAILED
    I have checked the wiring diagram and everything looks ok.
    Where could the problem be because I have run out of ideas.
    I've checked on 2 ESP8266 boards and a new C1101 will arrive today because I don't know if it's already damaged.
  • #2 21388441
    shysheq
    Hi! I’m also currently working on the CC1101 module and I’ve got a similar problem. Has it started working on your new module?
