PGE Seems Portal API for Retrieving Unbilled kWh from Photovoltaic Installations
azmurowski 1158 0
  • Hourly meter readings via modem in Seems Portal
    #1 21374700
    azmurowski
    Is there an API where it would be possible to retrieve the current amount of unaccounted kWh from a PV installation from PGE? Alternatively, a way to monitor these kWh?
    I have gas heating in my house, but also an air conditioning unit that I can heat when conditions are favourable. I would like to do this automatically if the temperature outside is favourable COP and I have enough free kWh.
    I have the control itself figured out, whereas I need to know how many free kWh I have without manually entering it.
    AI: Can you give more details about your photovoltaic installation and its integration with PGE? .
    5 kWh, hourly sending meter via modem
    AI: Do you currently use any monitoring system or software to track your energy consumption?
    I use Seems Portal
