[Solved] How to pair Aqara LED Strip T1 with Aqara M1S Gen2 Hub for HomeKit integration
nccom255games 1491 6
  • #1 21548852
    nccom255games
    How do I connect the Aqara LED strip to the Aqara M1S Gen2 hub?
  • #2 21549058
    Rate: 12907
    Can you provide more information, what specific model of LED strip, maybe a photo, maybe you have access to the manual?
  • #3 21565104
    nccom255games
    >>21549058 The model is a T1, it says after all.
  • #4 21565112
    Rate: 12907
    In the first post I don't see you specifying T1, but now you have and I have found the manual.
    Diagram showing an LED light strip with a controller and power adapter, plus descriptions of the controller's buttons. .
    51a923bb8 .
    You already have the hub and the app, yes? So according to the instructions, when the device is not detected, you have to press the On/Off button for a long time (more than 5 seconds) to restore the factory settings.
    • LED-Strip-T1-User-Manual-1.pdf (1011.85 KB) You must be logged in to download this attachment.
  • #5 21565126
    nccom255games
    It's detectable, I just want to set it to turn on at, say, 10 p.m. and off at 11 p.m. I don't think you've understood me.
  • #6 21565128
    nccom255games
    Sorry, I made a new topic for this and am writing on the old one. I really apologise.
  • #7 21565178
    Rate: 12907
    Be that as it may, I'm giving a link to a new topic:
    Aqara T1 LED - how to set automatic switching on at a specific time? .
The discussion addresses how to connect the Aqara LED Strip T1 to the Aqara M1S Gen2 Hub for HomeKit integration. Initial clarification confirmed the LED strip model as T1. The Aqara M1S Gen2 Hub and its app are prerequisites. According to the manual, if the LED strip is not detected, a factory reset can be performed by pressing the On/Off button for more than 5 seconds. The LED strip is detectable, but the user’s main interest shifted to scheduling automatic on/off times via the hub or app, which was identified as a separate topic. A link to a new discussion on setting timed automation for the Aqara T1 LED strip was provided.
