[Solved] Connecting the LED strip to the Aqara LLKZMK11LM relay - how to do it?
tomasz9106 1185 2
  • Need a separate 12 V or 24 V LED driver
    #1 21016283
    tomasz9106
    Good day,
    I would kindly like to know if it is possible to connect a led tape (white, not RGB) to a dual channel control relay, precisely to the Aqara LLKZMK11LM (only this model can be added to the Xiaomi app).
    I am only concerned with switching on and off the 4-5 metre long tape.
    I use this relay to operate led bulbs but I don't know how I could connect the led tape to it.
    If this is possible, could it be a 12v or 24v tape? Would I connect the power supply to the relay and the tape to the power supply? Sorry but I'm not familiar with this at all.
    Thank you for your help.
    kindlar
    Help: 919
    Rate: 1622
    The power supply after the relay and only the led strip.
  • #3 21110347
    tomasz9106
    That's what I did, it works. Thank you.
