Which Aqara Gateway Supports Both Xiaomi Lumi Zigbee Devices and Aqara E1 Switch?
Szymonix 834 0
  • Aqara gateway compatibility with Xiaomi Zigbee devices
    #1 21489144
    Szymonix
    Rate: 24
    Hi. I have a question regarding smart home in xiaomi and aqara environment. I currently have a xiaomi lumi gateway v3 that I bought a few years ago. I have several devices hooked up to it such as motion sensors, window opening, socket, temperature sensor. Everything works with zigbee. I also wanted to install a light switch instead of the standard one and bought one from aqara model E1. I was a bit deluded that this gateway would detect it, but it didn't. I was also ready to replace the gateway with an aqara one, but I wonder what about the devices connected to the xiaomi gateway? Will the aqara gateway handle them? What is the best model to choose so that aqara and xiaomi devices work?
    I should add that I don't plan to expand with any more devices well, unless more of these switches. I also don't want to play around with Home Assistant. Thank you in advance for your help.
