[Solved] Recovering BK7238 (XH-WB3S) After PowerSave Command: UART or Alternative Methods?
taggbricka 555 2
  • #1 21585079
    taggbricka
    Successfully got XH-WB3S (BK7238) with driver AHT2X and AHT30 sensor up and running.
    Then I wanted to try some power saving, with this startup:
    backlog startDriver SSDP; startdriver AHT2x 7 8 1 2; PowerSave 1
    That didn't go well. The BK7238 is not online anymore.
    How to recover? Connect to UART and reflash? Any simpler method?
    insmod
    Help: 168
    Rate: 455
    >>21585079
    Go to safe mode (quick reset 5 times) and disable powersave
  • #3 21585308
    taggbricka
    Worked great.
    Thank you.
