HP G62 Laptop Won’t Power On, 4 Blinks, Missing 5V Rail, Possible Charging IC Issue
abramkyr1995 585 2
  • Missing 5V rail points to charger or regulator fault
    #1 21585699
    abramkyr1995
    LAPTOP HP G62 (FOXCONN MOTHERBOARD).
    I have an HP G62 laptop. When I press the power button, it doesn’t turn on and the LED next to the power input blinks 4 times.
    Even with the battery connected, the same thing happens.
    I measured the 19V on the motherboard, and they are fine. The 3.3V rail is also OK, but the 5V rail is missing.
    Additionally, when the battery is disconnected, the laptop does absolutely nothing, and the power supply only shows 10mA consumption but doesn’t turn on.
    When the battery is connected, the charger tries to power the board, but every 4 seconds, there seems to be a short circuit, and then it tries again.
    I measured at the input (e.g. the 19V rail), and as soon as the short occurs, the voltage drops to 6–7V, then rises back up to 19V and the cycle repeats.
    What could be the problem? The battery or the charging IC?
    I tested all the input MOSFETs off the board and they are fine.
  • Identify the Foxconn board revision first
    #2 21586312
    lisek
    Service technician RTV
    Help: 6350
    Rate: 6880
    Measurements on the charger.
    - since the field measurements are good, perhaps the charger does not "open" them
    Which board from Foxconn for the HP62 ?
    - HP G62 ( Foxconn Safina PM_A_HPC_S MV_MB_V1)
    under AMD cpu
    charger max 8731
    SM you have for free Link
    - HP G62 ( Foxconn Federer PM_I_HPC_S MV_MB_V3 )
    HM55
    disc gpu HD5470 (216-0774009)
    Intel P6200
    Mobo under Intel Quanta AX1 ( DA0AX1MB6F0 )
    Find your mobo. and read about it what has already been written on this forum so far
    • foxconn_ Intel.pdf (1.42 MB) You must be logged in to download this attachment.
  • #3 21587091
    abramkyr1995
    >>21586312 FOXCONN PM_I_HPC_S_MP_A_A1_100503_R1.1 D1 STAR(Federer)
    This is the board.
    **When the battery is out of board the board from PS is taking 0.100 mA but don't start up -only LED is blinking 4 times.
    When the battery is plugged in the board is taking 3.15A (short) and voltage goes 14V and the only thing that gets hot is the coil of 19V.
    By the way, thanks for your reply!
