Tuya - how do you program the repetition of one action repeatedly ?
skaktus 9840 5
  • #1 20284754
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    Welcome.
    Is there any easy way to program the cyclic switching on and off of an outlet using Tuya e.g. switching on every 20 minutes for 2 minutes or is it just left to enter for each successive hour consecutively switching on and off and so on around the clock?
  • #2 20284773
    strazak26
    Help: 5
    Rate: 15
    via the schedule in the app - you select the first range and repeat every ....
  • #3 20284818
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    Shrinks are in the app. I can in the scenes select at what time it turns on and off. Nowhere do I see an option to cycle on and off.
  • #4 20284834
    strazak26
    Help: 5
    Rate: 15
    in Gosound is, I don't know which one you have
  • Tuya scheduler lacks cyclic on/off intervals
    #5 20284841
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    I have Gosund paired with Tuya. I will check the app for Gosund soon.
    Installed. Apart from a different icon, I don't see any differences with Tuya. Are you able to write a path how you do the cyclic on/off ?
    I poked around some more - there is indeed a schedule. However, this is no different from setting it manually. I was more concerned with a setting like - every 20 minutes turn the unit on for 2 minutes, after 2 minutes turn it off.Then give - repeat all day, 7 days and that's it. In the schedule, unfortunately, you have to set each hour separately. All in all, nothing, but every now and then I have to change the intervals between switching on, on different sockets different operating times and intervals. Doing this manually takes a lot of time. The scheduler simplifies things to a minimum, although this is not what &#128521 was intended;
  • Scene-based relay cycling with 20-minute delay
    #6 21249600
    TomKomar
    Maybe so:
    Scene:
    1. (when any condition is met)
    if relay is OFF
    2a. delay the action 20 min
    2b. set the relay to ON
    2c. set the relay contdown to 2 min
    It will work like this:
    The script starts when the relay turns off. Then: it waits 20 min, then turns the relay on for 2 min, and after that it starts again (because the relay has turned off), i.e.: it waits 20 min, turns the relay on for 2 min, etc ....
    You can also give conditions in the preconditions until when it should work (e.g. when the outside temp <7 )
