DP100 Atomic Point Power Supply Unboxing, Size Comparison, and First Impressions
unikeyic 723 0
  • DP100 size and accessory comparison with 65W charger
    #1 21614557
    unikeyic
    Rate: 22
    I. Unboxing
     ① I was thrilled when I received the notification that my trial application was approved.
     ② DP100 is the official launch of the atomic point. I have also seen. At the time of watching, the feeling is not great; I think it's just very general.
     ③When I saw the launch, I realized that this power supply was something I had no concept of in terms of size.
     ④New realization: only after use will one feel the performance of things, their imagination, and personal use of two different things.
     ⑤The following will be introduced in the experience.
     Before unboxing: the black box in the lower left corner of the picture, with the Positive Point Atom logo on it
    Note: To test the DP100, test tools have been prepared in advance
    Note: I prepared my own 65W gallium nitride power supply, mhp30 soldering station (60W), and a zero ohm resistor
    Close-up of keyboard, Positive Point Atom case, Thinkplus charger, and MHP30 box
    After opening the box, all things were as shown
    Note: The main components are DP100 power supply workbench
    Note: Accessories are alligator clips, power cord (red and black), USB cable - A port to A port, DC to TYPE-C cable
    DP100 kit: power supply, alligator clip wires, USB cable and DC-USB-C adapter
    Close-up of open case with three cables: alligator clips, USB, and DC-USB-C
    Second, experience
    DP100: feel very small, but doubt that I can take 100W sense of skepticism
    Note: not very heavy in the hand
    Note: It is recommended to do weight, so as not to use on the desktop, which will be wired to drive the DP100 to move or turn over
    DP100 power supply on white background next to a colorful chart with IC parameters
    Note: Surprised only half the size of a cell phone
    DP100 power supply next to Xiaomi smartphone on white background
    Note: the actual size of the picture
    DP100 power supply on white background next to measuring ruler and circuit board
    Note: A 65W gallium nitride charger is almost as big as. I have been surprised by this.
    DP100 power supply, MHP30 station, Thinkplus charger and USB cable on white background
    DP100 power supply and USB-C cable on white background
    Note: The alligator clip power cord is very soft. More than 100 times more comfortable than my Fluke multimeter cable!
    Red and black test wires with banana plugs and alligator clips
     Third, use
     Just their first use of the steps
    Note: The first power on the direct automatic boot
    Close-up of DP100 power supply with active screen and a hand pressing a front button
    Note: After powering on, press Changan, the leftmost button, to display shutdown
    Close-up of powered-on DP100 power supply with visible buttons and connected cables
    Note: DP100 front is straightforward, three buttons + a wheel key
    DP100 power supply with active LCD screen, control buttons and rotary knob visible
    Note: DP100 left side view, as the power supply 0-30V adjustable output port
    Close-up of DP100 power supply terminals with LED lights: blue (minus) and red (plus)
    Note: DP100 right side view, TYP-C as the power input
    Note: USB can double-click the center button with a square icon two times to enter the menu
     ① master mode: output 5V/1A; insert the mouse to control the DP100 interface settings
    Close-up of USB-A and USB-C ports on DP100 power supply
     ② from the mode: USB cable - A port to A port cable connected to the computer. The APP controls output parameters and can see any output power waveforms. Do not need to operate the physical buttons in the DP100
    DP100 power supply connected to a laptop running monitoring software
    Note: After powering on, press the center key (among the three keys). You can set the output (voltage/current). This set of settings is saved in the first preset data
    Close-up of DP100 power supply with connected wires and active OLED display
    Note: You can preset 10 output values (voltage/current)
    Close-up of DP100 power supply with cables and settings screen
    Note: After setting (voltage/current), you must press the start output button as shown in the picture; otherwise, it will not be output.
    Close-up of DP100 power supply with active display and connected wires
    Note: No output is measured without pressing the output button.
    DP100 power supply connected to digital multimeter and test leads
    Note: Press the Start Output button. You will see the left side of the two connected to the crocodile clips, output LED lights on
    DP100 power supply connected to digital multimeter with test leads and LCD screen
    DP100 power supply with OLED screen and three front control buttons
     Fourth, the summary
     I prepared a lot of tests, as I had not taken into account the input interface, which resulted in the DP100 being unable to power up for testing. For example, I created a test trial video for the next direct recording.
     ① mhp30 because of the need for PD protocol power supply, I'll prepare a PCB adapter board next time. Measure the heating temperature rise with the power curve of the welding table
    The Apollo STM32H4 board of Positive Point Atom. I will prepare a PCB adapter board next time and prepare to run the system with DP100 to detect the real-time power.
     ③ Qiyin Telen's voice control board, with DP100 test Bluetooth control cell phone playing music + a variety of voice control commands performed by the power jumps
     ④ I want to buy a DP protocol testing instrument, which is currently broken. Failed to negotiate the price in the second-hand market for a fish
     Later, to make up, a variety of test equipment, a test video
     DP100, this trial test, gives me a better sense of seismicity. It is to use the function of fast; it is easy to get started.
     Looking forward to my test video; next time, I'll make up a post.
