Why is it necessary to design power bricks to get too hot to handle?
321 7
  • Power bricks run hot due to efficiency tradeoffs
    #1 21658082
    Bob Casiano
  • #2 21658083
    Olin Lathrop
  • Dell 90W brick survives extreme heat and abuse
    #3 21658084
    Ben
  • #4 21658085
    DAVID CUTHBERT
  • #5 21658086
    Bob Casiano
  • Cost-driven underspecification of power supplies
    #6 21658087
    Ralph Pruitt
  • #7 21658088
    DAVID CUTHBERT
  • Power supplies should run far cooler than 63C
    #8 21658089
    Steve Greenfield
Power bricks for consumer electronics often run very hot due to design trade-offs involving size, cost, and reliability. Manufacturers may prioritize minimizing production costs, sometimes resulting in power supplies that operate near their maximum allowable temperature limits. Safety standards such as UL60950 and EN60950 specify maximum surface temperatures for external plastic and rubber parts, typically up to 95°C, which is close to scalding temperatures. Some brands, like Dell with their 90W power bricks, demonstrate that supplies can endure high temperatures without failure over extended periods, though the heat generated can be uncomfortable or potentially damaging to surfaces. The design approach balances thermal performance with cost efficiency and warranty considerations, occasionally leading to power supplies that run hotter than ideal. Historical examples include older Commodore 64 power supplies, which required aftermarket cooling modifications to reduce heat. Users concerned about excessive heat may consider measuring surface temperatures and replacing power supplies that exceed safe or comfortable thermal thresholds.
