Safe Switching Circuit for Capacitor Discharge in 250VDC Jewelry Spot Welder Project
558 32
How can I switch a 250VDC capacitor discharge so the welding leads only become live when the probes touch the workpiece?
Use a power MOSFET or, simpler, an SCR/thyristor to gate the capacitor discharge only when the probe contact is made; an optoisolator can keep the control side isolated, and a MOSFET for 250VDC should have a Vds rating comfortably above the maximum, about 375V by the 150% rule [#21660498][#21660508][#21660514] If you go the MOSFET route, the thread notes that N-channel parts are more common, but the circuit polarity has to suit the device, which is why the opto-isolator idea was suggested for using an N-channel in an isolated control arrangement [#21660509][#21660514] The later SCR approach was presented as the cleaner fit: an SCR only needs about 10–30 mA to trigger, and a part like the 2N6397G is rated 12A/400V with 100A non-repetitive surge, though it will have a voltage drop and dissipate heat during the pulse [#21660523] That SCR circuit was also described as working over a variable 70–250V input as long as the gate trigger current stays within limits [#21660525] If you can redesign the welder, lowering the voltage and paralleling several low-voltage capacitors was suggested as a safer way to get the needed current while reducing shock risk [#21660517]
  • Questions about optoisolator use and 4017 output current
    #31 21660527
    Steve Lawson
  • Opto used as LED replacement in 4017 circuit
    #32 21660528
    Sarah Harris
  • #33 21660529
    Sarah Harris
The discussion centers on designing a safe and user-friendly switching circuit for discharging a charged capacitor at up to 250VDC in a jewelry spot welder application. The main challenge is to enable instantaneous switching at the weld point to ensure the leads become live only during the short circuit, minimizing shock risk. Proposed solutions include using P-channel and N-channel MOSFETs as switches triggered by contact resistance, with considerations for voltage range (70V to 250V) and current handling capabilities. The difficulty in sourcing suitable P-channel MOSFETs led to exploring N-channel alternatives and polarity reversal via opto-isolators for isolation and control. SCRs (thyristors) were also considered due to their cost and surge current capacity, with analysis of their slower switching speed and higher power dissipation compared to MOSFETs. Practical issues such as capacitor longevity under repeated shorting, the use of photoflash capacitors, and the possibility of capacitor banks switched sequentially by a 4017 decade counter were discussed to improve refresh time and welding frequency. Additional circuit elements like voltage indicators (10-LED bargraph), latching circuits for inverter control, and footswitch alternatives were evaluated. The importance of proper gate drive, polarity, and current limiting components (diodes, resistors) was emphasized to ensure reliable operation and safety. References to educational resources on MOSFET operation and circuit simulation tools (CircuitWizard) were provided to aid understanding. Overall, the conversation highlights the trade-offs between component availability, electrical characteristics, safety, and user ergonomics in developing a capacitor discharge switch for high-voltage spot welding.
TL;DR: Build a contact‑activated discharge so probes stay safe until touch; an SCR here “can take 100A for a few milliseconds.” Use MOSFET/SCR gating, opto‑isolation for polarity, and mind zeners and surge energy. [Elektroda, Steve Lawson, post #21660523]
Why it matters: You get safer, repeatable micro‑welds for jewelry without live leads between shots—reducing shock risk and burnt tips for DIY builders.
How do I make the welder leads only go live at the moment of contact?
Use a contact‑sensing switch: a MOSFET gate biases on only when the probes touch the workpiece (low resistance). In Steve’s sketch, SW2 is the weld point; the P‑channel MOSFET stays off until contact, limiting idle current to microamps. This keeps the tips high‑voltage but not hazardous between welds. Add proper gate resistors and a bleed path so it turns off cleanly after separation. “The MOSFET only turns on when the welding probes contact the metal.” [Elektroda, Steve Lawson, post #21660498]
Is a foot switch a good idea for triggering the discharge?
It’s simple and rugged, but contacts can pit or weld shut under surge. A hybrid works better: use the pedal to arm, and a MOSFET or SCR to commutate the actual discharge. Steve’s hybrid also adds a charge indicator so you don’t fire early. If you do use a pedal, pick a heavy‑duty momentary model and keep the high surge out of the switch. [Elektroda, Steve Lawson, post #21660504]
What MOSFET voltage rating should I choose for a 250 VDC welder?
Use about 150% headroom on Vds to handle spikes and a noisy environment. For 250 VDC, select a MOSFET with at least 375 V Vds (higher if your wiring is inductive). Keep Rds(on) low to minimize heating, and observe SOA for single‑pulse energy. If P‑channel parts are scarce, consider polarity reversal with an opto to use tougher N‑channel devices. [Elektroda, Steve Lawson, post #21660508]
Can this work across a wide 70–250 V charge range?
Yes, but your sensing and gate‑drive must track voltage. Steve provided a revised scheme that accommodates 70–250 V by adjusting bias so the device only enables under proper contact. Verify trigger thresholds at both extremes, and add a resistor divider with adequate power rating. Test at the lowest and highest voltages before regular use. [Elektroda, Steve Lawson, post #21660510]
Should I use an SCR (thyristor) instead of a MOSFET?
An SCR can work and is inexpensive. Tradeoffs: slower turn‑on (microseconds), fixed voltage drop, and required gate current. Steve notes ~1.8 V drop at 10 A and ~5.6 V at 100 A, which is 560 W instantaneous loss—acceptable for short pulses but watch thermal shock. Quote: “this baby can take 100A for a few milliseconds.” Size for surge and add proper snubbing. [Elektroda, Steve Lawson, post #21660523]
What does “Peak Non‑Rep Surge Current 100 A” on an SCR mean?
It’s the single‑pulse surge the device can survive for a specified short duration, not a continuous rating. In this thread, the 2N6397 was called out as handling around 100 A for a few milliseconds, making it suitable for brief capacitor discharges if kept within limits. Ensure your wiring, clamps, and layout can deliver the pulse without inductive overshoot. [Elektroda, Steve Lawson, post #21660523]
How can I safely use N‑channel MOSFETs if my design is negative‑ground?
Insert an opto‑isolator in the control path. Drive the opto LED from your logic, and use the opto transistor to reference the high‑side gate appropriately, letting you flip secondary polarity and keep logic ground safe. This enables using robust N‑channel MOSFETs while maintaining isolation and correct biasing. [Elektroda, Steve Lawson, post #21660514]
What if my low‑voltage and power supply share earth ground?
Keep the original polarity and reference intact. Sarah flagged that reversing ground wasn’t viable because LV and the power supply share common earth. In that case, use isolation to avoid moving the ground, or re‑arrange only the high‑energy side with proper creepage/clearance. Don’t break protective earth to “make it work.” [Elektroda, Sarah Harris, post #21660507]
How do I reduce shock risk while testing the welder?
Keep open‑circuit touch voltage under 50 V where possible, and avoid energizing with open probes. Steve warned a protection zener might blow when you hit the foot switch with no load. Use insulating habits, discharge bleeders, and a charge indicator. Quote: the zener “might actually blow out” if first hit open‑circuit. [Elektroda, Steve Lawson, post #21660504]
Will standard electrolytic capacitors survive repeated short‑circuit discharges?
Users report standard caps fail quickly under repeated shorts. Photoflash‑rated capacitors are built for high peak currents and frequent pulses, but large values at low voltage are bulky and costly. Sarah noted difficulty sourcing affordable, large‑value photo‑flash caps; plan around available parts or series/parallel banks. [Elektroda, Sarah Harris, post #21660519]
Can I speed up refresh with multiple capacitors and a 4017 sequencer?
Yes. Sarah proposed ten parallel output stages, each with its own cap and SCR, selected sequentially by a 4017. Steve called it clever but warned that many 4017 outputs would sink current simultaneously; buffer outputs or add resistors, and confirm the opto/LED currents. Run the 4017 near 9 V for reliable drive. [Elektroda, Steve Lawson, post #21660527]
Quick how‑to: contact‑activated discharge switch in three steps?
  1. Sense contact: route probe tips to a detector node that biases a MOSFET gate only when resistance is low.
  2. Switch energy: place the MOSFET in series with the cap and weld path; add gate resistors and a snubber.
  3. Indicate/bleed: include a charge indicator and a bleed to reset between welds. [Elektroda, Steve Lawson, post #21660498]
What is an SCR (thyristor) in this context?
An SCR is a latching, high‑current switch triggered at its gate. Once on, it stays on until current falls below its holding current, which suits single‑pulse capacitor discharges. It needs gate current and has a fixed voltage drop; size it for surge current and dv/dt. [Elektroda, Steve Lawson, post #21660523]
What is an opto‑isolator and why use it here?
An opto‑isolator transfers a signal via light, isolating control logic from the high‑energy discharge side. In this project, it lets you flip secondary polarity and use N‑channel MOSFETs without tying logic ground to the welder’s high side, improving safety and flexibility. [Elektroda, Steve Lawson, post #21660514]
What is a 4017 decade counter and any cautions?
A 4017 is a CMOS counter with ten decoded outputs that advance on each clock. For cap‑bank sequencing, ensure each output’s LED/opto current is limited or buffered, since several outputs may sink current at once. Steve suggests operating it at around 9 V. [Elektroda, Steve Lawson, post #21660527]
Can I run the design at lower voltage but higher capacitance for safety?
Yes, lower voltage reduces shock risk; multiple low‑voltage capacitors in parallel cut ESR and boost pulse current. Steve suggested 3–4×300 µF at ~35–50 V for safer handling, with selectable banks for heat control. Verify capacitor pulse ratings and wiring inductance. [Elektroda, Steve Lawson, post #21660517]
