Best eBay search terms for PCB etching: copper clad board, ferric chloride, alcohol resist
402 6
  • #1 21662390
    Zacques Z
  • #2 21662391
    Mark Majewski
  • #3 21662392
    Zacques Z
  • Ferric chloride and B327 etchants linked
    #4 21662393
    Mark Majewski
  • Ammonium persulfate recommended as PCB etchant
    #5 21662394
    Steve Lawson
  • Laser printer toner transfer for simple PCB layouts
    #6 21662395
    Yoram Stein
  • #7 21662396
    Zacques Z
The discussion focuses on identifying effective eBay search terms and materials for PCB etching, specifically for use with alcohol-resistant methods. Key etching chemicals mentioned include ferric chloride (FeCl3) and sodium persulfate (Na2S2O8, also known as B327), with ferric chloride being a traditional etchant and B327 a modern alternative. It is noted that ammonium persulfate is a common etchant, but no known etchant works directly with alcohol as a solvent since alcohol can dissolve permanent marker lines used as resist. For resist application, oil-based permanent markers are recommended over standard permanent markers for better durability during etching. Alternative PCB fabrication methods such as toner transfer using laser printers and photoresist techniques are also discussed, with photoresist providing higher resolution. Safety concerns about using hydrochloric acid (HCl) and hydrogen peroxide (H2O2) as etchants are raised, suggesting caution with these chemicals. Links to eBay listings for ferric chloride and alternative suppliers for B327 are provided to assist in sourcing materials.
