Using TAS5630 Analog Input PWM Amplifier for Vocal/Keyboard Amplification?
330 7
  • #1 21663172
    Leslie Perjes
  • #2 21663173
    Cody Miller
  • #3 21663174
    Leslie Perjes
  • Avoid phased-out parts for production designs
    #4 21663175
    Steve Lawson
  • #5 21663176
    Steve Lawson
  • #6 21663177
    Leslie Perjes
  • #7 21663178
    Steve Lawson
  • TAS5630B has lower offset and lower 2 ohm power
    #8 21663179
    Leslie Perjes
The TAS5630 is a Class D analog input PWM amplifier primarily designed for home theater and DVD player applications. It is possible to use it for vocal and keyboard amplification, but considerations include the chip's "Not Recommended for New Design" (NRND) status, indicating it is being phased out. For new designs, Texas Instruments recommends the TAS5630b, which is functionally equivalent but with some differences: the TAS5630 supports 2 Ω speaker impedance with clipped output at 600W, while the TAS5630b supports 3 Ω at 400W and 2 Ω at 480W unclipped, which may risk failure. The TAS5630b also has a lower output offset voltage (typical/max 20/50 mV) compared to the TAS5630 (40/150 mV), improving performance. Using the TAS5630 for instrument amplification is feasible, but designers should consider availability and replacement issues due to NRND status, especially for production or multiple units. PCB designs for TAS5630 can potentially be adapted for TAS5630b due to their equivalence in functionality and parametrics.
