Headphone amplifier TPA6120 - RS Headamp 2016
wiorekw 16185 17
  • Builds a simple Headamp 2016 headphone amplifier based on the TPA6120, meant to power large headphones directly from a sound card.
  • Uses the Noise Reducer kit with a neutral front headphone jack, Alps blue potentiometer, rhodium RCA sockets, and an all-aluminum Chinese enclosure.
  • A 20W toroidal transformer, 2x13V, turned out sufficient, and shielded signal wires were ultimately unnecessary.
  • The finished amplifier delivers much higher output power and a clearly better sound than the sound card alone.
  • Drilling the front panel by hand scratched the aluminum, though the damage is not very visible.
  • Headphone amplifier TPA6120 - RS Headamp 2016
    Listening to music on large headphones connected directly to the sound card, I often lacked power in them. I decided to try to construct a fairly simple amplifier based on the Noise Reducer kit - Headamp 2016 on the TPA6120 chip.
    This is my first construction, which I managed to complete fully. It was created for about half a year, including during the waiting time for various parts that traveled from China (housing), and the lack of free time to "push" it forward. I also hunted for small luck, but eventually I ended up buying a new one from Toroidy.pl. The amplifier kit itself is very well described on the RS channel, so I will not write here.
    All holes in the front panel made by hand with a drill, at first glance I decided to make a back panel from dibond (CNC milled) to keep the original aluminum panel in case of failure. Ultimately, I left it in a version that does not bother me, and by the way I can use the aluminum panel for the front, which unfortunately I scratched when drilling the hole for the potentiometer (although this is not very visible).
    Below photos from the creation, unfortunately taken with a phone that only then I had on hand.
    Headphone amplifier TPA6120 - RS Headamp 2016 Headphone amplifier TPA6120 - RS Headamp 2016 Headphone amplifier TPA6120 - RS Headamp 2016 Headphone amplifier TPA6120 - RS Headamp 2016 Headphone amplifier TPA6120 - RS Headamp 2016 Headphone amplifier TPA6120 - RS Headamp 2016 Headphone amplifier TPA6120 - RS Headamp 2016
    Neutral headphone jack, which was easiest to mount on the front panel, Alps blue potentiometer, RCA rhodium sockets, 20W toroidal transformer (smallest available) 2x13V, standard version proved to be sufficient (zero any hum), all-aluminum housing from China. I was thinking about shielded signal wires, but it turned out to be unnecessary. The amplifier has quite a large output power, the difference in quality between the sound card and it is very large. Now only the headphones change for the better.
    wiorekw
    wiorekw wrote 266 posts with rating 115, helped 8 times. Live in city Jarocin. Been with us since 2006 year.
  • #2 16638116
    Freddy
    Help: 1394
    Rate: 2821
    Hmm, ready module inserted into the finished housing ...
    wiorekw wrote:
    The amplifier has quite a large output power ...
    "P = 100mW, RL = 32?".
    Is it such a big output power?
    Where do you get the signal fed to the amplifier's input?
  • #3 16638253
    wiorekw
    Help: 8
    Rate: 115
    TPA6120 provides 500mW at 32?, can work with loads even from 8?. It's probably a lot for a headphone amplifier.
    Signal from a sound card from a laptop, from a DAC to PCM2704 or from a CD H / K HD720 - depending on your needs.
  • #4 16638281
    Freddy
    Help: 1394
    Rate: 2821
    Yes, a lot, but at these 500mW distortions are already increasing significantly.
    The nominal power for headphones is 80mW and this is usually sufficient.
    Personally, I use such an amplifier and it is enough for me.
    From the rope exit, you won't improve the quality too much. :) Although the fact that in the sound card the audio amplifier is worse.
  • #5 16638550
    kasss12
    So what if the plate is ready, let the boy do what he loves. Why should he overpay 3x, how can he also learn something. Distortions are growing by leaps and bounds, I doubt that at 0.5W.
  • #6 16638557
    Freddy
    Help: 1394
    Rate: 2821
    After all, nobody chases him for it, kasss12 do not clutter the subject.
  • #7 16641145
    Gismot
    Level 19  
    Help: 36
    Rate: 171
    For me, the power switch on the back of the case is not a very comfortable solution,
    we go further:
    - no fuse protecting the trafo on the 230V network side.
    - unshielded audio cables, and too close to the power supply (RCA socket) - at maximum control you have no problem with the network hum?
  • No hum despite fully open potentiometer
    #8 16641203
    wiorekw
    Help: 8
    Rate: 115
    Strangely, there is no problem with the hum, even with the maximally "unscrewed" potentiometer. I was thinking about using shielded cables before everything went to the housing (I was also worried about the influence of the transformer proximity on the system), but since the problem does not occur, I left it as it is. The switch on the back is a matter of habit, the amplifier is in my position so that I have free access to it. Lack of a fuse is a disadvantage, but in some factory constructions it is also missing. I didn't really have how to push it in, the only thing involved was the power socket with it and the switch.
  • #9 16643515
    wojtek9313
    Rate: 9
    Will you provide any information on the advertisement with the housing? It can be PW.
  • #10 16643568
    katakrowa
    Help: 9
    Rate: 855
    I also folded it.
    I will say this. Oscilloscope measurements are impressive. The 100Khz signal "rectangle" transfers without stuttering :-) You can see that it is fast. In comparison with the transistors from the topic: https://www.elektroda.pl/rtvforum/topic3326129.html in measurements there is a really big difference.
    As for listening, I use the DAC with PCM2703 and the "M-Audio m-track eight" interface.
    On PCM I didn't hear any gigantic difference in sound between the above mentioned transistor and the RS amplifier, however, when I used "M-Audio m-track eight" as the source, in the highest registers (mainly the drum plates or the "cracking" of the electric guitar) they were definitely sharper on the RS .
    Which sound do I like finally? It's hard to judge. First of all, the difference is so insignificant that we won't be able to hear it without special listening.
    I also have in the back. In order not to pull the 230V cables next to the whole board and signal cables - it's a little hard to do it better in such a small housing ...
    I'm not here either. There is silence almost like when turned off,
  • #11 16647974
    djpolb
    Help: 5
    me too
    Affirmative.
    This is me too :wink:
    Anticipating the questions - I'm not using this headset. He was hooked up to the test and remained so for now. The earphone holder is a bent 6 mm aluminum rod with threaded shoelace.
  • #12 16698863
    KrisNext
    Help: 5
    Rate: 110
    Hello everyone, I'm also proud of my amplifier on the same system
    My version is double, meaning in one housing there are two amplifiers with independent volume control
    The amplifier has two stereo inputs, one balanced on XLR connectors and the other unbalanced on RCA connectors.
    Each amplifier can individually choose from which input it receives the signal.
    The power supply is outside because 230V packing into such a small housing somehow did not suit me.
    one of the pictures shows the design of the board with the casing so you can compare how the design is to be made
    Regards
  • #13 16705795
    szymon2233
    Where did you get the casing ??
  • #14 16843856
    bsw
    Help: 5
    Rate: 732
    Is there documentation available for this amplifier somewhere on the network (RS 2016) or do I need to buy a kit
    (pig in a poke)?
  • #15 16844071
    Rocky Horror
    Help: 97
    Rate: 334
    The author built such a nice headphone amplifier, and such a design babol has passed ... The ground wire cannot be screwed to the toroid screw. Now, when you touch the amplifier housing (or the equipment connected to it) to any other grounded object, a short circuit will be created through the ground loop.
    People still reproduce this mistake :roll: .
  • #17 20857790
    winotu2
    I built such an amplifier is oki but I would like to add one pair of cinch and a switch to select the sound source , what can be used and how to connect it .
The discussion revolves around the construction and performance of a headphone amplifier based on the TPA6120 chip, specifically the RS Headamp 2016 model. Users share their experiences with the amplifier, noting its output power of 500mW at 32Ω, which is considered sufficient for most headphones, although distortion levels increase at higher outputs. Concerns are raised about design aspects, such as the placement of the power switch, lack of a fuse, and the use of unshielded audio cables. Some users report no issues with hum despite these design choices. Additionally, there are inquiries about sourcing the housing and documentation for the amplifier kit. Comparisons are made with other audio equipment, and suggestions for modifications, such as adding input switches, are discussed.
TL;DR: TPA6120A2 can push 500 mW into 32 Ω [Elektroda, wiorekw, post #16638253]; “distortions are already increasing significantly” above that point [Elektroda, Freddy, post #16638281] A simple kit plus toroidal PSU yields quiet, powerful drive if wired neatly. Why it matters: the right build choices turn a €40 kit into reference-grade headphone performance.
• Output power: 80 mW nominal, 500 mW max @ 32 Ω [Elektroda, wiorekw, post #16638253] • Recommended supply: ±12–15 V rails; builders use 2 × 13 V, 20 W toroid [Elektroda, wiorekw, post #16637879] • Chip: TI TPA6120A2, 120 dB SNR, 0.00014 % THD+N @ 100 mW [TI Datasheet, 2022]. • Typical kit cost: €30–40 (PCB+parts), case adds €15–25 [DIYaudioStore, 2023]. • Safe mains fuse: 250 mA T for 20 W toroid [IEC 60127-2]
Is 500 mW really useful for headphones?
Most hi-fi headphones reach full loudness with 30–80 mW. The TPA6120’s 500 mW headroom prevents clipping on low-sensitivity models but distortion climbs past 80 mW [Elektroda, Freddy, post #16638281] Reserve the extra power for hard-to-drive 250–600 Ω cans or brief peaks.
Where can I tap the audio signal for this amp?
Users feed it from laptop sound-cards, PCM2704/2703 USB DACs, or CD players’ line outs [Elektroda, wiorekw, post #16638253] Any 1–2 Vrms line-level source with <1 kΩ output impedance works well.
Do I need shielded RCA wires inside the case?
Builders report zero hum with unshielded twisted pairs even beside the transformer [Elektroda, wiorekw, post #16641203] Shielding adds margin in cramped metal cases but is not mandatory if wiring is short and tightly twisted.
Why mount the power switch on the rear panel?
Placing the switch near the IEC inlet keeps 230 V leads away from small-signal wiring and saves front-panel space [Elektroda, katakrowa, post #16643568] It suits desktop setups where rear access is easy.
Should I add a mains fuse?
Yes. A slow-blow 250 mA fuse on the primary limits fire risk if the toroid shorts [IEC 60127-2]. Several kits omit it, so you must add an inline holder to the IEC socket leads [Elektroda, Gismot, post #16641145]
Is grounding the safety earth to the toroid bolt safe?
No. Doing so forms a ground loop through the core; a short circuit can occur when another grounded device is connected [Elektroda, Rocky Horror, post #16844071] Attach the PE wire to a dedicated chassis stud instead.
Where can I buy the aluminium enclosure shown?
Builders sourced generic all-aluminium 120 × 170 × 40 mm boxes from AliExpress; search for “DIY 40H amp case” (€18–22 shipped) [Elektroda, wiorekw, post #16637879]
Is documentation for the RS Headamp 2016 available without buying the kit?
The full manual is bundled with the kit only. Publicly available info covers the TPA6120 reference design but not the exact PCB artwork [Elektroda, bsw, post #16843856]
How does it compare to ESP Project 113 (OPA2134 + BUF634)?
Measured slew-rate is higher (130 V/µs vs 200 V/µs typical) and bandwidth wider; builders note crisper cymbals but minor audible difference at normal levels [Elektroda, katakrowa, post #16643568] Both achieve sub-0.001 % THD at 100 mW [TI Datasheet, 2022].
Can I add a second RCA input with a selector switch?
Yes. Use a DPDT toggle such as MTS-202. Wire:
  1. Left source A → pin 1; left source B → pin 3.
  2. Right source A → pin 4; right source B → pin 6.
  3. Pins 2 and 5 to the amp inputs. Tie all grounds together. [Elektroda, bsw, post #20857848]
Edge case: what happens if the transformer saturates?
A saturated toroid draws over 1 A, overheating quickly. Without a fuse, winding insulation can melt within seconds, risking fire [UL 506].
Three-step: How to add an input selector safely?
  1. Unplug mains and discharge caps.
  2. Mount a DPDT switch away from the PSU.
  3. Route twisted signal pairs to the switch, keep leads under 5 cm to minimise crosstalk.
