Is It Safe to Use Neutral as Ground for 240V Infrared Rework Station in USA?
549 25
Can I use the neutral or a nearby outlet’s ground as the equipment ground for a 240V infrared rework station in the US?
No—neutral should not be used as the equipment ground, and you should not borrow ground from a nearby outlet. The safety ground and neutral are bonded only at the service entrance; using neutral as ground may make the equipment work, but it is not safe and is not by code [#21665342][#21665345][#21665357] If the station only needs 240V, use the two hot conductors plus a real equipment grounding conductor on a proper dedicated circuit, ideally with a 4-wire outlet/receptacle installed by a qualified electrician [#21665342][#21665349] Do not use the ground from another 120V receptacle because you do not know its wiring rating and it can create a dangerous condition or ground loop [#21665342][#21665345][#21665351] For overcurrent protection, use the manufacturer’s recommended breaker and wire size; one reply notes that a 16.5A load is beyond the usual 80% continuous-load limit of a 20A breaker, so a 25A or 30A 2-pole common-trip breaker may be needed depending on the equipment and wiring [#21665342][#21665349][#21665359]
  • Neutral is not a safe equipment ground
    #1 21665336
    Just A Noob
  • #2 21665337
    Earl Albin
  • Need a knowledgeable electrician for proper 240V wiring
    #3 21665338
    Just A Noob
  • Australian perspective on the 4-pin grounding issue
    #4 21665339
    Peter Owens
  • Safety-first argument for following licensed electrician procedures
    #5 21665340
    Earl Albin
  • Neutral must not be used as ground for safety
    #6 21665341
    Peter Evenhuis
  • Do not borrow ground from nearby outlet
    #7 21665342
    Chuck Sydlo
  • Using a separate outlet ground for 240V safety?
    #8 21665343
    Just A Noob
  • Suggesting a 4-wire outlet and GFCI breaker upgrade
    #9 21665344
    Just A Noob
  • Neutral must not be used as ground for 240V
    #10 21665345
    Peter Evenhuis
  • Neutral-to-ground bond does not make a safe equipment ground
    #11 21665346
    Just A Noob
  • Liability warning about unsafe neutral-to-ground advice
    #12 21665347
    Mark Harrington
  • Neutral is not true earth and can be dangerous
    #13 21665348
    Mark Harrington
  • Neutral is not a safe substitute for ground
    #14 21665349
    Patrick Walsh
  • #15 21665350
    Earl Albin
  • Ground loops can create dangerous voltage differences
    #16 21665351
    Chuck Sydlo
  • #17 21665352
    Earl Albin
  • #18 21665353
    Just A Noob
  • Questioning earth wiring practices in UK and US outlets
    #19 21665354
    Peter Owens
  • US 240 V uses two hot conductors on different phases
    #20 21665355
    Patrick Walsh
  • #21 21665356
    Patrick Walsh
  • Clarifying grounding electrode bonding and code requirements
    #22 21665357
    Patrick Walsh
  • Ground-loop risk from inverter and solar grounding
    #23 21665358
    Chuck Sydlo
  • Neutral-ground bonding acceptable for 240V-only load
    #24 21665359
    Jeffrey Pardus
  • Neutral-ground bond only at service panel in homes
    #25 21665360
    Peter Evenhuis
  • #26 21665361
    Mark Harrington
In the USA, using neutral as a ground conductor for a 240V infrared rework station is technically possible but unsafe and against electrical code. Neutral serves as a current-carrying return path, while ground is a dedicated safety conductor designed to trip breakers in case of insulation faults. Mixing neutral and ground can cause electrical fires, electrocution hazards, and insurance invalidation. Older 3-prong dryer outlets lack a separate ground conductor, often relying on plumbing for grounding, but modern code requires a 4-wire system (L1, L2, Neutral, Ground) for 240V appliances. Running a ground wire from a different 120V outlet is also unsafe due to potential ground loops, voltage differences, and unknown wire ratings. Proper installation by a licensed electrician with a dedicated 4-prong outlet and adherence to NEC (National Electrical Code) is strongly recommended to ensure safety and code compliance. The discussion also highlights the importance of a single grounding point at the panel to avoid ground loops and the risks of using neutral as ground, including shock hazards and interference from lightning strikes. Some users shared practical experiences and emphasized that while older installations may have tolerated such wiring, modern safety standards and insurance requirements mandate correct grounding practices.
TL;DR: For a 240V rework station, do not use neutral as ground. Follow the 80% continuous-load rule statistic and, as one pro put it, “load a circuit to a maximum of 80%.” Use a proper equipment grounding conductor and a 20–30A 240V receptacle. [Elektroda, Patrick Walsh, post #21665349]
Why it matters: This FAQ helps US makers and repair techs wire 240V tools safely without code‑violating neutral/ground shortcuts.
Is it safe to use neutral as ground on a 240V infrared rework station?
No. Neutral is a current‑carrying conductor; ground is a safety path. “Technical it works YES but SAFETY it is a NO.” Use a dedicated equipment grounding conductor. [Elektroda, Peter Evenhuis, post #21665341]
Can I bond the machine case to the ground from a nearby 120V outlet?
Do not. That ground conductor may be smaller and overheat during a fault. Run a proper grounding conductor in the same cable as the hots feeding the tool. [Elektroda, Chuck Sydlo, post #21665342]
Do I need a neutral if my tool is purely 240V heating elements?
If the load is strictly 240V, you do not need neutral. You still must provide a separate equipment grounding conductor for the chassis. [Elektroda, Peter Evenhuis, post #21665345]
Why are neutral and ground bonded only at one point?
Bonding occurs at the service entrance to hold everything at the same potential and give faults a low‑impedance path. Additional bonds elsewhere create shock and fire hazards. [Elektroda, Patrick Walsh, post #21665349]
What receptacle and plug should I use for a 16.5A 240V device?
Use a straight‑blade NEMA 6‑20 (with a 20A two‑pole breaker) or NEMA 6‑30 (with a 30A two‑pole breaker). Label it 250V only. [Elektroda, Patrick Walsh, post #21665349]
What breaker size fits a 16.5A max load?
Apply the 80% rule for continuous loads. 16.5A exceeds 80% of 20A, so use a ≥25A circuit; many choose 30A with proper wiring and fusing. [Elektroda, Patrick Walsh, post #21665349]
Do I need a GFCI on a 240V rework station circuit?
A GFCI breaker is not typically required for this stationary appliance type. Follow manufacturer instructions and local code. [Elektroda, Chuck Sydlo, post #21665342]
What is a ground loop, and why is a separate ground rod risky?
A ground loop is an unintended current path between different grounds. A separate, unbonded electrode can sit at thousands of volts during surges or lightning, risking fires and damaged electronics. [Elektroda, Chuck Sydlo, post #21665351]
How does US split‑phase power deliver 120V and 240V?
Two ungrounded conductors (L1, L2) are 180° apart. L1–neutral or L2–neutral gives ~120V. L1–L2 gives ~240V for higher‑power loads. [Elektroda, Patrick Walsh, post #21665349]
How can I safely repurpose a 3‑prong dryer circuit for 240V‑only equipment?
  1. De‑energize, identify the cable, and re‑identify the former neutral as equipment ground per instructions.
  2. Install a 250V‑only receptacle (e.g., NEMA 6‑30R) and two‑pole common‑trip breaker.
  3. Fuse the tool appropriately at its first connection point. [Elektroda, Patrick Walsh, post #21665349]
What happens if the neutral opens under load?
Circuits using neutral see full 120V potential appear where you expect zero. Touching it to ground can arc like a welder. Residential breakers often have 10,000A interrupt ratings, so faults escalate fast. [Elektroda, Patrick Walsh, post #21665349]
Can I use plumbing as a ground for my appliance?
No. Do not use a water pipe as a substitute for the equipment grounding conductor. Run the ground with the circuit conductors and bond correctly. [Elektroda, Chuck Sydlo, post #21665342]
What is an equipment grounding conductor (EGC)?
An EGC is a dedicated, non‑current‑carrying safety conductor that connects metal enclosures to the service bond, clearing faults rapidly by tripping protection. [Elektroda, Patrick Walsh, post #21665357]
Why is tying neutral to ground in a subpanel dangerous?
Bonding neutral to ground downstream bypasses the dedicated fault path and energizes metal parts. It cripples subpanel safety and violates the single‑bond rule. [Elektroda, Patrick Walsh, post #21665349]
