Low Cost Digital Oscilloscope Design: AC/DC Coupling, Analog Front End, MCU Interface
288 10
How can I design a low-cost digital oscilloscope with AC/DC coupling, an analog front end, and microcontroller interfacing?
Start from an existing digital-scope reference design or open-source scope platform instead of building the whole analog front end from scratch. One useful reference is the BitScope site’s Circuit Cellar INK article on how to make a digital scope, issue 97 (August 1998) [#21665364] Another practical starting point is Gabotronics’ low-cost oscilloscope setup, listed at about $49, where they provide the layout and software [#21665370] Their design is described as open source, with free schematics, board layout, and software that you can modify to fit your own AC/DC-coupled hardware needs [#21665373]
  • #1 21665363
    alpesh Patel
  • #2 21665364
    Steve Lawson
  • Oscilloscope access as a tool for experimentation
    #3 21665365
    Olatunde Aroloye
  • #4 21665366
    Steve Lawson
  • #5 21665367
    Richard Comerford
  • #6 21665368
    alpesh Patel
  • Nostalgic case for building your own oscilloscope
    #7 21665369
    Mark Harrington
  • Advocates learning hardware design over module reliance
    #9 21665371
    Mark Harrington
  • #10 21665372
    alpesh Patel
  • Open-source oscilloscope design can be customized
    #11 21665373
    Peter Evenhuis
The discussion focuses on designing a low-cost digital oscilloscope featuring both AC and DC coupling, with emphasis on the analog front end and microcontroller interfacing. References include a Circuit Cellar INK article (Issue 97, August 1998) available via BitScope, which provides detailed circuit design guidance. Another practical resource is the open-source oscilloscope project by Gabotronics, offering hardware schematics, PCB layouts, and software for a $49 kit suitable for educational purposes and modification. The conversation highlights the importance of understanding hardware design beyond software development to avoid over-reliance on pre-built modules. The target design bandwidth mentioned is around 20 MHz, suitable for student laboratory use. The analog input section design considerations include implementing AC/DC coupling and integrating the analog front end with microcontroller interfaces for signal acquisition and processing.
