Transistor-Based Class A/AB MP3 Headphone Amplifier Design with Tone & Volume Control
342 8
  • #1 21670478
    Ash Tatpati
  • #2 21670479
    DAVID CUTHBERT
  • #3 21670480
    DAVID CUTHBERT
  • #4 21670481
    Ash Tatpati
  • #5 21670482
    DAVID CUTHBERT
  • #6 21670483
    Tina Mildred
  • #7 21670484
    Tina Mildred
  • #8 21670485
    Conrad Mannering
  • #9 21670486
    Max Maxfield
✨ The discussion focuses on designing a transistor-based Class A or Class AB headphone amplifier with tone and volume control, powered by a PP3 battery, targeting improved sound quality over an unamplified MP3 player output. Key design specifications include an input impedance of at least 100 kΩ, output impedance below 100 Ω, frequency response covering 20 Hz to 20 kHz, and inclusion of volume and tone or cross-feed controls. A suggested approach involves a multi-stage amplifier with a JFET or MOSFET input stage to achieve the high input impedance, followed by bipolar transistor output stages configured as emitter followers or push-pull for efficiency and low distortion. A shared schematic operates at approximately 7.5 V (compatible with 6–9 V PP3 battery range), featuring an input impedance of 800 Ω (not meeting the 100 kΩ target), output impedance around 30 Ω, voltage gain between 4 and 7 depending on load, frequency response from 18 Hz to 10 MHz at -3 dB, and a quiescent current of 11 mA. The amplifier is single-ended and AC coupled. The BSS123 N-channel MOSFET is recommended for the input stage to meet the input impedance requirement. It is noted that while the amplifier can increase volume, it cannot inherently improve the original audio quality beyond amplification. Some responses included spam links unrelated to the technical discussion.
